#Camaro6
Go Back   CAMARO6 > Technical Camaro Topics > Wheels | Tires -- Sponsored by The Tire Rack
BeckyD @ James Martin Chevy
Old 01-25-2021, 09:03 PM   #1
Skyman2112
Skyman2112's Avatar
Drives: 2016 2SS blue velvet w/blk stripes
Question 285/35s on the front of a 2016SS???
i saw a shot of MMR Z28 wheels that were 20x10 +23mm with 285/35s on front. Rear had 20x11 +43mm with 305/35s. Has anyone tried this on the Gen6 to see if it rubs? The caption reads 25mm offset on the front but they only offer them in 23mm. I really dont want to use 30 aspect tires if this setup will work. Any opinions appreciated, thanks
Skyman2112 is offline   Reply With Quote
Old 01-26-2021, 05:42 AM   #2
warren3537
warren3537's Avatar
Drives: 2019 Red Hot ZL1 1LE: 2012 RAM 2500
I had them on my 17 1SS and with a 3mm spacer then it puts them out to 20mm and no rubbing, things were real close but no rubbing, I hope this helps.
warren3537 is offline   Reply With Quote
Old 01-26-2021, 07:07 AM   #3
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
This is a Goodyear Supercar 3R in 285/35/20 on the front of a Mag Ride 2016 SS on a 23mm offset MRR M017 WITH a 12mm spacer. (Effective offset of 11mm) They would clear with less spacer but this was a test fit to run these on the track so I used my big spacer for more clearance.
Old Ride: 2016 Callaway SC630 Camaro SS
TheRealJA105 is offline   Reply With Quote
Old 01-26-2021, 04:55 PM   #4
shaneotool
Drives: 2016 Camaro SS
I'm planning on going with 275/35 and 315/30 on my Mrr M017 wheels.
Very close in diameter to the stock SS diameters, and verified by a few as to not rub.
shaneotool is offline   Reply With Quote
Old 01-26-2021, 06:01 PM   #5
Skyman2112
Skyman2112's Avatar
so basically no way without spacers. THanks
Old 01-26-2021, 06:02 PM   #6
Skyman2112
Skyman2112's Avatar
yeah i think 285s wont fit. Gonna do 275s instead.
Old 01-26-2021, 06:03 PM   #7
Skyman2112
Skyman2112's Avatar
what wheel were you using?
285s, front tire offset, gen6 wheels
