08-02-2013, 08:50 PM | #1 |
Drives: 2016 Chevy Camaro SS Join Date: May 2012
UEGO Wideband
Hey guys, maybe someone here has an idea. I just installed my UEGO Wideband and it does its natural start up. It then falls back down all the way to 10.0 and doesnt move. Was wondering if anyone had this issue? I had just installed some LT headers the day before. I havent got a tune yet and so far I have CAI, Corsa exhaust, Kooks LT's. Any help would be greatly appreciated.
Ryan Green
2016 Chevy Camaro SS Hyper Blue Metallic 2012 Chevy Camaro SS 45th Anniversary - SOLD (still kicking myself for doing that) Order Status 2000 - 1/4/16 2500 - 1/6/16 3000 - 1/7/16 - TPW 2/1/16!!! 3400 - 1/18/16 3800 - 1/30/16 - VIN# 145458 4300 - 2/2/16 4B00 - 2/4/16 4300 - 2/13/16 - Moving somewhere 4200 - 2/16/16 - SHIPPED!!!!! 5000 - 2/18/16 6000 - 2/19/16 - Its MINE!! |
08-02-2013, 09:04 PM | #2 |
Drives: 2023 ZLE Join Date: Jun 2009
More info required. Do you mean it goes to 10:1 AFR?
08-02-2013, 09:22 PM | #3 |
no it says 10.0 and doesnt move anymore from that while driving.
Ryan Green
08-02-2013, 09:38 PM | #4 | |
Here is a short video of what I am talking about.
Ryan Green
08-02-2013, 09:46 PM | #5 |
Have you performed the free air calibration on the sensor?
08-02-2013, 09:49 PM | #6 |
Double check all your wires. Make sure you have a good ground, power source and that the wire from the wideband sensor is not pinched or shorted. Not familiar with that brand, but I would think most work the same. You should see that reading constantly fluctuating. And as said before, do the calibration.
There's more to life than gas mileage
LS3, Whipple, Custom Comp Cam, springs, pushrods, timing set, CAI intake, Apex cold air scoop, Doug Thorley TRI-Y headers, Billet Custom Products baffled Valve covers, Mighty Mouse Catch can, ADM FPCM, ZL1 fuel pump, MSD boost-a-pump, Hex Vent hood vents, ProSport gauges(fuel pressure, AFR, Boost), Corsa, 100 cell Cats. Jannetty remote tuned, Pfadt trailing arms, all parts user installed. No Dyno yet. Manual trans. 3.45 gears. |
08-02-2013, 09:49 PM | #7 |
no, all I did was install it. Found power, routed it from the header through the firewall and into the back of the gauge.
Ryan Green
08-02-2013, 09:53 PM | #8 |
I suggest you follow the install instructions to the letter.
08-03-2013, 10:06 PM | #9 |
Update - Alright guys, so it was traced to a faulty wire connection. I had snipped all the wires in order to pass them through the firewall and I used a different type of connector when I should of taken the extra steps to solder the wires together and wrap them in heat shrink. Either way, it now works and I appreciate everyone's insight.
Ryan Green
