03-07-2014, 10:00 AM | #1 |
Drives: 2010 Chevy Camaro 2SS RS Join Date: Jun 2011
2010 2SS and what oil filter do you use?
Says it all. Let me know .
03-07-2014, 10:23 AM | #2 |
Drives: 2018 Hyper Blue 1SS 1LE Join Date: Jul 2011
Ac delco
Ryan
Ryan
* 2018 1SS 1LE Camaro Hyper Blue Metallic Car Build: http://www.camaro6.com/forums/showth...0#post10049680 |
03-07-2014, 10:31 AM | #3 |
High-tech Redneck
Drives: '10 CGM SS, '02 2500HD, '09 300SRT8 Join Date: Nov 2010
WIX - Oil Filter
Part Number: 57060
"My friends call me Chris. Are you my friend?"
2010 CGM L99 2SS/RS - GPI SS3 VVT, BTR DoD Delete, Circle D 4c, BTR springs, Katech C5R Timing Chain, MRR-228 315/275, CAI, Elite catch-can, TSP 1 7/8" Headers + offroad pipes, Magnaflow 3", Pfadt springs, BMR LCAs, toelinks, trailing arms, cradle bushings, & sway bars w/ endlinks, Vitesse paddles, heritage grille, and an eBay splitter. Power upgrades by Race Proven Perf.; Tuning by ShorTuning. |
03-07-2014, 10:45 AM | #4 |
Drives: 2010 Camaro Auto Join Date: Mar 2010
Here ya go. You apparently missed this post that is two below yours.
http://www.camaro5.com/forums/showthread.php?t=325861
Just livin' life Last edited by 2SSCAMARO; 03-07-2014 at 10:46 AM. Reason: typo |
03-07-2014, 11:46 AM | #5 |
Too much is never enough!
personally i use the K&N oil filter its not to cheap but ive cut a few apart new and used to see if there worth it and hands down i would use the K&N....now if its under warranty then i let the dealer use an ac delco cus the last thing i want to hear is asses and elbows over an internal engine issue ...but mine is no longer in warranty
03-07-2014, 11:51 AM | #6 |
Drives: Evil Eva, 2010 2SS LS3 Join Date: Aug 2013
I have been using the Amsoil filter and oil
"You simply cannot trust quotes found on the internet." -Abraham Lincoln
03-07-2014, 11:56 AM | #7 | |
03-07-2014, 04:59 PM | #8 |
Slow Turtle
The black KN filters are identical to the delco filters (its the same piece). The white ones with the hex on the bottom are a little better.
03-07-2014, 05:07 PM | #9 |
Whipped
K&N
03-07-2014, 05:11 PM | #10 |
Captain Gingerbeard
Drives: 2012 IOM RS/SS 6MT Join Date: Feb 2013
Shell Rotella-T 5w40 and a Purolator Pure 1 oil filter.
03-07-2014, 05:13 PM | #11 |
376 cubic inches of fun
AC Delco PF-48.
03-07-2014, 06:02 PM | #12 |
Dimitri
Drives: 68 GTO 455 Ram Air; 2014 Camaro ZL1 Join Date: Jan 2014
OEM
03-08-2014, 12:53 AM | #13 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
When in doubt, use OEM
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
03-20-2014, 06:56 PM | #14 |
C5 Best Gen
Drives: 2015 Camaro SS Join Date: Aug 2013
AC Delco PF-48
