Old 03-23-2010, 07:01 PM   #1
xpanda305x
Banned
Drives: Dark Knight
Gear/Transmission Grind! >.<
why does it happen? M6 V6
xpanda305x is offline   Reply With Quote
Old 03-24-2010, 04:06 PM   #2
jnm2003
jnm2003's Avatar
Drives: O2 GMC & 2010 camaro SS IBM 6M
Price of crap tremec 6060 tranny. Alot of people on other forums I'm on just for random knowledge have problems with them! I've heard that using mobil 1 has helped SOME people with the grinding. I'm having the problem too with 3000 miles so I'm gonna try it for this weekend when I change my oil. Btw everyone has diff opinions on what's the best tranny oil. Thru my research and people I know I feel like mobil 1 ATF will be my best bet! I'm on many diff forums also and that's my opinion. I would say try it and/or do research also! Some have bad synchros, some have worn out clutch fluid so it not fully disengaging when shifting, some it's their actual shifter.
2010 camaro SS/RS Manual IBM.
NEW TIME 12.24 @ 114 mph. -[B] street tires, Hurst short throw, Halltech yellow jacket intake, AR long tube 1 7/8 headers, and a tune.
12.82 @ 110 MPH 1.92 60ft ALMOST Bone Stock ONLY MOD IS Borla mufflers.
jnm2003 is offline   Reply With Quote
Old 03-24-2010, 04:39 PM   #3
Robert91RS
Robert91RS's Avatar
Drives: Everywhere
Not on his V6. The V6 doesn't use ATF either.
Robert91RS is offline   Reply With Quote
Old 03-24-2010, 05:25 PM   #4
xpanda305x
Banned
Drives: Dark Knight
what should i do then?
Old 03-24-2010, 06:31 PM   #5
SS 376
SS 376's Avatar
Drives: 2010 IBM 1SS (Former)
You should explain the problems you're having a lot more. When did problems start, what gear grinds, do you hear noise or just feel harshness, does it do it when cold, etc.? Then C5 ppl can help you out.
SS 376 is offline   Reply With Quote
Old 03-25-2010, 12:44 AM   #6
jnm2003
jnm2003's Avatar
my bad didnt even notice you put LS. Sorry!! I would do a fluid change/flush on the tranny and clutch. If its anything like what we are experiencing in our SS's then it will probably help!! I know its different cars but I think GM is putting Crap fluids in these cars stock. My rear differential after just 3000 miles came out looking like i was draining primer grey paint from it. Another friend did his with 1700 miles and the same result. from what ive seen on mine and two other friends cars it seems like gm half a**ed it on using good break in fluids! DONT let the dealer tell you its the way that sport cars or new camaros or anything else all are bc its B.S. I seen a few people go to the dealer and them say its normal and they did a fluid change themselves and is workin fine now! and some actually had synchro issues
Old 03-25-2010, 08:48 AM   #7
Robert91RS
Robert91RS's Avatar
Drives: Everywhere
Easy dude. Yes a fluid change may be of assistance but lets not go telling every new member false truths. GMs fluid is good stuff and IF its not the best, its only because the average joe wouldn't buy a car that required such high maintenance cost not to save a buck. New parts break in on all cars!!!!!!
To the OP, if you can speak with your dealer calmly about your concerns you may be able to convince them to do a fluid change for you. If you go in telling them about the shitty fluid GM uses....well...probly not.
Old 03-25-2010, 09:48 AM   #8
NightmareSS
NightmareSS's Avatar
Drives: 2010 Camaro SS/RS 92 300zx 2001 Ram
interesting...sometimes when i shift from first to second i feel a lil grind and i have the clutch pedal down all the way...so you think i should change the tranny fluid?
NightmareSS is offline   Reply With Quote
Old 03-25-2010, 09:54 AM   #9
Robert91RS
Robert91RS's Avatar
Drives: Everywhere
It can't hurt. Just be sure to use the right fluid.
Old 03-25-2010, 10:21 AM   #10
Moorepheus
Drives: 2013 Dodge Charge R/T Plus AWD
I really don't undestand why your gears are griding. I only have 600 on my car and the only time my grid is if I lift my clutch early before I am in gear......which I only have done once. I have felt NO GRID at all, in any gear, upshifting or down shifting.
Moorepheus is offline   Reply With Quote
AY6 grind, 1st to 2nd... 75rusty V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 66 10-10-2014 11:50 AM
Anyones exhaust tip ports have grind marks? AWS-GTAW Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 2 03-24-2010 05:30 PM
need some help >.< youngkim Wheels and Tires Talk Sponsored by The Tire Rack 15 02-28-2010 06:54 PM
Belt grind after Warmup Die Zielscheibe Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 1 12-13-2009 05:39 PM
Hoping for Karmic Retribution >.< Tsudy 5th Gen Camaro SS LS LT General Discussions 15 10-26-2009 11:51 PM
