02-23-2012, 08:05 PM | #1 |
2010-2012 Camaro V8 New Era OTR Intake System Powdercoated 2010-2012 Camaro V8 New E
I was going to buy the Cold Air Inductions CAI today when I ran across the New Era OTR Intake. I couldnīt seem to find anything on it and the description on the website is not too specific. Does anyone know how or where the actual filter mounts? Anyone running this setup that have pics a video or some helpful info
02-23-2012, 08:10 PM | #2 |
Drives: Wagon Queen Family Truckster Join Date: Oct 2009
the filter is inside that metal box in the front, over the radiator. It is shaped like a long rectangle.
02-23-2012, 08:31 PM | #3 |
Recalled user
Drives: '12 Camaro SS, '18 Colorado Z71 Join Date: Mar 2009
I've been wondering about this one too. Seems like its better quality than the vararam.....?
2012 2SS 45th AE LS3 M6 Borla ATAK Catback Kooks Stepped LT Headers CAI Intake Hexvents VMAX CNC Ported Throttle Body RX Catch Can Hurst Short Throw Shifter Pfadt ZL-Spec Stage 3 Suspension Forgestar F14 Tuned by Frost |
02-23-2012, 11:21 PM | #4 |
02-24-2012, 06:48 AM | #5 |
I have one on my car, no tune. Never had any problems with it at all, I love it! It looks great! I have not put my car on a dyno since I installed it, so I can't really tell you any specific HP gains. I think most CAI systems only gain 5-10 HP anyway, so the butt dyno really isn't reliable.
02-24-2012, 09:35 AM | #6 | |
02-24-2012, 10:48 AM | #7 |
Talked to the guys at Jannety racing and they said I am better of going with a CAI enclosed intake it will produce more hp and is 100 dollars cheaper
02-24-2012, 01:52 PM | #8 |
ʇuɐıʌǝp lɐıɔos
Drives: 2011 2SS/RS LS3/M6 Join Date: Feb 2011
Here are some pics and a thread (post #14) showing the Jannetty Racing CAI test comparing dyno runs of various CAIs including the New Era OTR. As you can see from the test, Jannetty is correct that some enclosed intakes will produce more hp on a dyno with the car sitting still (maybe with some fans also blowing toward it). But what about in real world conditions with a 40, 60, or 80 MPH wind coming directly at the car? The CAIs that can take advantage of this air will be the better performers. These include the Vararam, New Era, and some others that use a scoop from under the car. So a question I ask myself was how can a dyno test be a truly accurate indicator of how one of these type CAIs will perform with a 60 MPH head wind? I came to the conclusion that it can't. So then it became a question of which one of the 3 CAI's mentioned above could take best advantage of air rushing toward the car? Obviously, either the Vararam or the New Era since by tilting the radiator back, you are creating one giant scoop funneling air directly into the intake. This was a major factor I considered when deciding on a CAI. At this point I was down to Vararam and New Era. The New Era uses a standard size K&N air filter while the Vararam does not. A point for New Era. The New Era is very well built (aluminum) and sturdy. It also has a better designed method of securing the radiator. You can see this in the 2 close up pics where the ears with rectangular holes fit over the bosses on the top of the radiator. The rubber pieces were my idea to prevent movement. A point for New Era again. Another factor was temperature climb. Only 3 CAIs in the test had 0 climb. New Era and Cold Air Inductions. Two other, although minor, considerations were reducing clutter under the hood by eliminating the air box and coolness factor (probably at least a 9). For the sake of balance, there was a negative in choosing this CAI and that was price. At $490, the New Era was one of if not the most expensive CAI out there, but in my mind it was worth it and what the hell it's only money. In the end, everyone has to decide what seems right for them and what they will be happy with. Hope this helps you in your decision, whatever you decide to go with.
02-24-2012, 01:57 PM | #9 |
Recalled user
I'm impressed. It looks awesome. Wonder if it's compatible with the 2012?
02-24-2012, 02:23 PM | #10 |
02-24-2012, 02:32 PM | #11 | |
02-24-2012, 02:45 PM | #12 |
Drives: 2012 Camaro 2SS 45th Anniversary Ed Join Date: Oct 2011
That's a cool looking intake.
2012 Camaro 2SS 45th Anniversary Edition - No longer owned: 2010 Camaro 2LT, 1993 Camaro Z-28
02-24-2012, 02:46 PM | #13 | |
ʇuɐıʌǝp lɐıɔos
Isolators were made using round rubber grommets from Lowe's or Tractor Supply. Measure the square hole diagonally and get that size grommet, then cut it to fit. The reason I got them was I saw a picture where vibration had caused the bracket to wear into the plastic boss. |
02-24-2012, 02:54 PM | #14 | |
Similar Threads | ||||
2012 V6 C.A.I. Inc. | Camaro 3.6L Cold Air Inductions Intake System! | Plus Packages! | AutoAgenda | V6 Bolt-Ons & Tunes | 87 | 08-25-2013 05:22 PM |
What do all the abbreviations mean? | CrzyGamr2 | 5th Gen Camaro SS LS LT General Discussions | 77 | 12-07-2012 04:34 AM |
Modern Camaro Performance Parts - www.PartsTaxi.com | PartsTaxi.com | Sponsor Announcements / Giveaways / Contests | 0 | 10-06-2010 04:26 PM |
Think about this and the Z28 5th gen | 13F20 | Camaro ZL1 Forum - ZL1 Specific Topics | 41 | 09-04-2010 12:59 AM |
Latest Camaro Products - March 2010 | Sean@Phastek | V8 Bolt-Ons & Tunes | 26 | 08-04-2010 04:42 PM |
