01-29-2011, 07:53 PM | #1 |
Drives: 2010 IOM 2SS/RS Join Date: Jan 2010
Eibach guys I need help
I drive my car on the street. I am not concerned with track days or shaving fractions of seconds off of my times. I am looking to drop the car about an inch but am worried about the effect on ride quality. Eibach pro plus seem like a great way to achieve this goal but I would love some feedback before I make a purchase.
01-29-2011, 08:01 PM | #2 |
Drives: 2010 rs ss Join Date: Jan 2010
Look's great .. the ride, not so much. If i had the money i'd go with the coilovers. I only drive this car on the weekend so i just deal with the ride.
01-29-2011, 08:08 PM | #3 |
Coil overs simply aren't an option. I only drive mine a few times a month.
01-29-2011, 08:10 PM | #4 |
For the same money I would suggest BMR 1 inch springs. They offer a better ride than the Eibachs.
01-29-2011, 09:02 PM | #5 |
Drives: BLACK 2SS/RS Join Date: Sep 2009
Any drop spring will give you a slightly stiffer/firmer ride.If installed properly there is no bounce,no noise,etc. I think the ride quality is just fine with the Eibach springs......as with most other brands of drop springs as well.
[IMG]http://i736.photobucket.com/albums/xx5/fenemij/DS****30.jpg[/IMG]
CCW polished 505a's
Front 20x10 w/275/40/20's Rear 20x11.5 w/305/35/20's Eibach 1" Pro Spring Kit Factory GFX MPD1 spoiler painted bowties 15% tint |
01-29-2011, 09:07 PM | #6 |
Thanks alot for the input. I think I will go ahead with the eibachs.
01-30-2011, 02:14 AM | #7 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
Any drop spring you go with is going to give you a stiffer ride, PERIOD. The question is, what is too harsh for you. I have the Pfadt springs and really like the added stiffness. I felt the OEM springs had too much spring to them. Since ride quality is different for everyone, you'll need to ride in a few lowered cars to see what feels good to you.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
01-30-2011, 04:27 PM | #8 |
Drives: SuperSport's Join Date: May 2009
^^^ true just do not ride in a German stock lowered vehicle. Their cars ride so good and sit real low. Every car I have ever owned has a 1.25-1.50" drop. Please do not forget its a Chevy Camaro not a AMG-Benz, M-series BMW or S-line Audi !!!
2002 Chevy CamaroSS MN6
'08 Chevy TBSS AWD "DD" Plans : 2013 CamaroSS 1LE |
02-03-2011, 12:40 PM | #9 | ||
Drives: Camaro Justice Join Date: Jun 2007
Pedders SportsRyder lowering coils. Our SportsRyder lowering coils will work on both the six and the eight with a 657mm front ride height (1.4" drop) and either 675mm (1" Drop) or 660mm (1.57" Drop) rear ride height. These are no ordinary coils. These are coils manufactured to Pedders standards of +/- 1mm. Each coil is fully scragged and height verified before it is placed in a Pedders box. Coils that literally do not measure up are discarded as junk, not reworked. Coils that fail this test are not reworked. They are shipped out as scrap metal. When you purchase a Pedders Camaro Coil Set you have purchased what some brands would call a race matched set. Our coils are designed to work with the OE dampers and bumpstops. Ride quality is not OE but it is certainly not boy racer. Most would say ride quality is close to OE. Quote:
Similar Threads | ||||
2010+ Camaro V8 & V6 Eibach Pro-Kit Performance Lowering Springs - Drop Your Ride! | AutoAgenda | Suspension / Chassis / Brakes | 14 | 12-08-2010 11:36 AM |
Eibach Front Camber Kits IN STOCK ~ $32.99 SHIPPED!! | AJ@ECSMotorsports | Suspension / Chassis / Brakes | 5 | 11-13-2010 03:45 PM |
EIBACH SPRINGS & SWAY BAR KIT $500 | ADKINS PERFORMANCE | Suspension / Chassis / Brakes | 0 | 08-09-2010 11:14 PM |
does eibach make the SLP SPRINGS & Sway BARS | bob2010ss | Suspension / Brakes / Chassis | 3 | 07-22-2010 08:31 AM |
