Old 08-20-2011, 02:19 PM   #1
CamaroBC
CamaroBC's Avatar
Drives: Cyber Grey 2LT RS Coupe
Theres no coolant in my car?
Does the DIC tell you when you need more coolant? Because a friend of mine looked under the hood and said I didnt have any.
And if so what do I use to fill it up?
CamaroBC is offline   Reply With Quote
Old 08-20-2011, 03:31 PM   #2
carbon8
Drives: 2010 Camaro SS,2008 Hayabusa
how did he know, did he pull the dip stick or check the radiator and yes it will tell you when it is low..you do know the overflow has a dip stick.
carbon8 is offline   Reply With Quote
Old 08-20-2011, 03:46 PM   #3
CamaroBC
CamaroBC's Avatar
oh he just pulled the dipstick near the electricity box. after looking in the manual Im now seeing the radiator cap is under the angine cover. Ive never messed with the engine yet.
So the disptick can show below the min mark and theres still coolant in there?
I am glad to hear thought that the DIC will let me know.
Also kinda weird that it seems so low when the manual says its supposed to be in there for 5 years? Under what normal circumstances would anyone on here have needed or gained the experience in changing the coolant on any 2010 and later model? Why? I bought mine preowned, the original owner bought it in dec 2009. I got it in feb 2011. Not even close to needing more according to the manual.
Old 08-20-2011, 04:11 PM   #4
13 ZL1
13 ZL1's Avatar
Drives: 2013 IOM ZL1
The previous owner may have done something that leaked some coolant or maybe it has always been low. All you need to do is add coolant to the overflow tank. It should be good after that as long as the radiator has not been running low. If it has then there will be air in the system and you will need to get that out.
13 ZL1 is offline   Reply With Quote
Old 08-20-2011, 06:17 PM   #5
carbon8
They might have changed something, like the thermostat or maybe some warranty work was done and like SSRS said they might not have got it full. My heater core went bad a month after I bought my SS and I took it to the dealer fir warranty work and when I got it back the coolant was low too. If you do decide to fill it up make sure you use the same coolant as what is currently in it.
- Daniel 
Old 08-20-2011, 10:53 PM   #6
CamaroBC
CamaroBC's Avatar
How do I find out what's currently in it .
Old 08-20-2011, 11:00 PM   #7
cowboy1948
cowboy1948's Avatar
Drives: 10 LT2/RS-08 SILVERADO-05 COBALT
Cool
I would just fill it up with distilled water. Never put tap water in a vechile rad.
Retired
cowboy1948 is offline   Reply With Quote
Old 08-21-2011, 01:13 AM   #8
carbon8
Go to your local automotive store and ask. It's going to be Dexcool. Get the 50/50 mix. That way all you have to do is pour it in.
- Daniel 
Old 08-21-2011, 06:12 PM   #9
MRGOODWRENCH3
Drives: 2010 Camaro 2SS/RS
The best time to check the radiator is in the morning after the engine has cooled down. Remove the cap and fill the radiator to the top. Drive it, then let it cool down. Fill the radiator complely. The reservoir bottle is not a accurate way to judge then level.
MRGOODWRENCH3 is offline   Reply With Quote
Old 08-29-2011, 05:25 PM   #10
UHP-CAMARO
UHP-CAMARO's Avatar
Drives: Traded this for a 2013 ZL1
Never just add water, it may bite you in the Butt this winter.
Always use the 50/50 pre mix.
UHP-CAMARO is offline   Reply With Quote
Old 08-29-2011, 07:47 PM   #11
carbon8
I ruined a 7000 dollar motor due to using water. What an idiot move I made huh.
Fastest camaro in OKC
Washing/Detailing for Newbies MRK III Z28 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 125 02-05-2024 09:55 PM
PQs Camaro [COTW 9/20/10] PQ Member Car Journals 5664 07-28-2020 12:10 AM
What's considered a Muscle Car? SyN General Automotive + Other Cars Discussion 125 09-25-2010 12:04 AM
The first week with un-pink camaro! (a review with pics) pinkcamaro10 5th Gen Camaro SS LS LT General Discussions 31 07-02-2009 07:54 PM
