12-20-2014, 12:06 PM | #1 |
Drives: 2010 Camaro 2SS with RS package Join Date: Mar 2014
Rough estimate on Ac belt replacement & installation?
Ac belt was making noise and I took it in and they moved it back on and they said if it starts acting up again they would need to replace. Any idea on the cost for replacement with installation? Thanks!
12-20-2014, 12:26 PM | #2 |
CamaroFans.com
Minimal time to change so shouldn't be too much. Just need the little tool that comes with the belt otherwise it's a bitch to get on.
When you say "moved it back on". That's not good and your belt is probably damaged already. I would get a new one, but then it's not something that's too critical as all it drives is A/C and it's winter now. |
12-20-2014, 12:38 PM | #3 |
Drives: 2012 2SS/RS Convertible Join Date: Aug 2012
15 minutes in your driveway with the right tools.
$500 and 2 days @ a dealer..
I'm only responsible for what I say, not for what you fail to understand.
12-21-2014, 01:51 AM | #4 |
wait you forgot about the touch up paint thats a extra week and 3 trips back.
12-21-2014, 07:40 AM | #5 |
Drives: One of the baddest handling Gen 5s Join Date: Feb 2011
That belt is like $40 bucks tops , just remove the intake tube install in the right order. I replace mine every 20,000 miles because mine sees track and is not electric assist. Replacing them at short intervals keeps them feeling sharp in the steering response dept. Maybe your tensioner is weak. Get the JRE supertensioner.
12-21-2014, 08:57 AM | #6 | |
CamaroFans.com
This is the A/C Belt |
12-22-2014, 09:41 AM | #7 | |
Dimitri
Drives: 68 GTO 455 Ram Air; 2014 Camaro ZL1 Join Date: Jan 2014
