08-20-2013, 04:18 PM | #1 |
Drives: 2012 camaro 1LS. M6 Join Date: Sep 2012
t5 splitter v6 only
has any one out there useds or seen a v6 with a t5 splitter on like the one sold on gen5diy site ....do they look as good as zl1 do..?
08-20-2013, 04:41 PM | #2 |
Drives: 2010 Camaro Join Date: Feb 2012
The member "kold" had the t5 and now he has de zl1 bumper installed. it looks sick...
t5 zl1 |
08-20-2013, 05:07 PM | #3 |
Drives: 2013 camaro ls; 2005 rx8 Join Date: Mar 2013
I have the t5 on mine...its great...good fitment and tough as nails
08-20-2013, 07:06 PM | #4 |
Drives: Summit White RS Join Date: Feb 2012
I also have the t5 splitter, can post pictures later. Love the look, don't think picture do it as much justice on here. It looks great on the car.
08-20-2013, 07:11 PM | #5 |
7 year Cancer Survivor!
Drives: 17 Cruze RS, 07 G6 GT, 99 Astro Join Date: Dec 2007
Could you take a measurement of the approach angle for me? I want to make sure before I get one that it won't scrape the front edge of it when entering or backing out of my driveway. Thanks
The Bird is the word! |
08-20-2013, 07:22 PM | #6 |
08-20-2013, 07:46 PM | #7 |
Thanks guys I going to get one soon
08-20-2013, 08:07 PM | #8 |
whenever you lengthen the lower part out it reduces the angle of approach even if it remains at the same height.
such as I show here in this illustration. its not to scale so Maybe if you can take a direct side view picture at road level I could get a good idea by taking one of my car without one and comparing.
08-20-2013, 09:30 PM | #9 |
Yes get what you are saying, don't know if I have a way to measure that angle. Can see what I can do tomorrow. Can tell you it is going to have to be a significant incline to scrape at standard ride height.
08-20-2013, 09:43 PM | #10 |
If you could take a direct side view if your car similar to my illustration I think I could get a pretty good idea of the angle, I would appreciate it.
08-21-2013, 04:55 PM | #11 |
08-21-2013, 05:03 PM | #12 |
Thanks, that is perfect. Now to take one of my car
Edit: I just went outside and using your measurement to the peak of the nose it looks like my car sits about 3/4" higher in the front than yours does. Could you take a measurement of how far it is from the ground to the bottom of the rubber air dam just in front of the tire? Mine is 5 1/2" if I am correct and mine does sit higher then the amount of angle change between mine before and after should put mine at about what yours was before the splitter. It may have something to do with your low profile tires compared to my 18" ones. if you could make that measurement I asked for it would confirm my calculations.
The Bird is the word! Last edited by Angrybird 12; 08-21-2013 at 05:57 PM. |
08-21-2013, 06:46 PM | #13 |
5 1/8" from the ground to the bottom of the rubber air dam.
08-21-2013, 07:17 PM | #14 |
Ok mine must not be sitting level but on a slight up slope causing mine to sit a little higher in the front, my driveway has a steep slope then it tapers down but it does slightly curve at the top, thanks
