01-20-2017, 09:00 AM | #1 |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
Track alignment
Greetings, all.
Went to get my track alignment today and discovered something not in the manual. The front strut bolts are one-time use and tty (torque to yield - 180ft-lbs + 1/4 turn). They must be replaced when changing camber. Just a heads up to make a stop at your local dealer parts counter before you go get the alignment done.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
01-20-2017, 09:05 AM | #2 |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
180 LbFt plus 1/4 turn, dayumm that's a lot of torque. I was actually wondering if we'd find out if the adjustable bits would slip during track use and screw up the alignment, but probably not with that much torque.
Oh, BTW I had the dealership do the track alignment on my car before delivery. I'll go grab the sheet and scan it. It ended up with more caster than the book number, and I'm perfectly fine with that. FWIW, the alignment feels fantastic, like a proper track car. Less tramlining than I expected, it's damn near zero. Highly recommended. I'm sure the tire wear will be amusing for around-town on these steamrollers.
2017 "M1SS1LE" in Hyper Blue w/PDR
01-20-2017, 09:34 AM | #3 |
Drives: ZL1 1LE Join Date: Oct 2016
How much front camber did you guys add?
That's one thing I plan on doing eventually, after talking to the MT drivers they stated the car has a slight understeer (very slight, not bad) and a bit of extra front camber would probably balance it out a bit more. What I am not sure about is how the car was set up during the MT drivers test. I can't seem to get a solid answer on alignment specs. If I had to guess, I would assume it may have already had the 'track' specs.
01-20-2017, 09:44 AM | #4 | |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
Take it for what it's worth... |
01-20-2017, 09:46 AM | #5 |
Drives: 2017 2SS Join Date: Jun 2014
What about replacing them with some grade-8 bolts, and then using loctite?
01-20-2017, 09:46 AM | #6 |
マスタング = 遅い
I had a Mazdaspeed3 I used as a daily driver a few years back (the car that made me try autoX) and I had a track spec alignment done. It had lots of rear toe in, and wore out the inside of the rear tires down to the steel belts in like 4000 miles if I recall...they were pricy Continentals too.
01-20-2017, 10:12 AM | #7 |
Drives: 2017 Camaro 1LE Join Date: Sep 2016
Great info Matt, thanks!
01-20-2017, 10:13 AM | #8 | |
Drives: 2017 SS 1LE Join Date: Oct 2015
01-20-2017, 10:35 AM | #9 |
Drives: 16 2SS 6MT NPP MRC / 15 K1300S Join Date: Mar 2016
I wonder if the one-time use thing is because of threadlock applied to the bolt during manufacture? i just added fresh Loctite and reinstalled.
Rohana RFX-5 10/11, M/T 275/305, Eibachs, Hellwigs, Hurst SS, DMS LT4 SC 596HP/589TQ, DMS Low-side, Kooks 2LTs, MBRP Race, Rotofab, MMS CC |
01-20-2017, 10:52 AM | #10 |
Drives: 2017 SS 1LE Join Date: Oct 2016
I have not seen the 1LE's FE4's street and track alignment specifications in the service information or the Hunter alignment database file (Dec 2016 release). I predict the dealer service information will be updated at some point with the FE4 specs, but I haven't seen it yet.
2017 SS 1LE Hyper Blue - PDR - TSSHKX
2017 SS 1LE Hyper Blue - PDR - VBHF63 |
01-20-2017, 11:58 AM | #11 |
Front 'street' camber is -1.3. Track is -2.
Not a tremendous difference. I don't daily my car much, but I'll be eyeballing the tire wear. I've heard the debate about one-time-use bolts also. For every possible warranty issue, I am doing what GM wants and documenting it. The 4 bolts and nuts were only $20.
2017 HBM SS 1LE
01-20-2017, 12:06 PM | #12 |
Hot Dog
Here's a scan of my alignment. It ends up being just a whiff of toe-in front and back, significantly less than factory.
If you don't want to click the PDF, it goes like this: *Front camber: -2.1° left, -2.0° right *Front Caster: 7.1 and 7.4 *Front Toe: 0.05° In per side *SAI = mid 16's *Rear camber: -1.5° *Rear Toe: 0.04 and 0.07° Just for perspective, the toe angle ends up calculating to about 2 hundredths of an inch per side, or half a millimeter, measured at the wheel lip. Basically zero.
01-20-2017, 12:42 PM | #13 | |
Drives: 2017 1SS/1LE Join Date: Sep 2016
01-20-2017, 03:09 PM | #14 | |
Hot Dog
I would qualify the factory alignment as quite good. Now, if you want to talk about bad, the 1.5° total front toe-out my Abarth came with from the factory, that's too much.
