08-10-2013, 10:19 PM | #1 |
Rx breather
I've been browsing through the V8 section. I've read a few threads where people were saying not to use the oil fill breather as it would let unmetered air in, throwing fuel trims off. Is this the same case on the V6?
08-10-2013, 11:17 PM | #2 |
COTW 9/16/13
Drives: 2011 2LT/RS Camaro IOM Join Date: Jan 2012
This has been a little controversial as of lately. I do not know if it is true or not but I took mine off and my car seems to be running better honestly. I don't know exactly how the check valve works some say is it only lets pressure out while others say it lets air in which could throw off the fuel trims but I honestly do not know which is true.
08-11-2013, 07:45 AM | #3 |
It will freely exhaust and meter air in. If you like the taste of oil, take yours and first blow, then suck (no crude joke meant) on the end of it. Not a lot of difference, but it is there. If you cannot suck air in or blow air out, the valve is not working.
I have no clue if mine does anything to help. Been running with it after running with the Vararam breather for some time. Did not notice any difference.
2010 2LT CGM Auto
Vararam CAI - Modern Muscle Ported Throttle Body - Vmax Black Iceolator - Custom Exhaust - Magnaflow Res X 11386 - 2.5" Pipe from X on Back - Magnaflow Round Mufflers 10416 - Lime Green Hood Spears - Lime Green Gill Stripes - SJM AutoProd Sequential Turn Signals - SJM AutoProd Always On DRL Fog Lights |
08-11-2013, 07:47 AM | #4 |
Drives: ELLE-1 Join Date: Jul 2011
leave it off you dont need it....
