Old 05-17-2013, 04:18 PM   #1
jcieutat
Drives: 2013 SS 1LE
Borla 11775 Installation
My exhaust just came in the mail today. I was under the impression that it was a easy bolt on swap. After reading the directions, it seems as if I need to cut the factory exhaust. Can anyone confirm this? If so, will a reciprocating saw with a metal blade work for the cut?
2013 Camaro 1SS 1LE Inferno Orange
jcieutat is offline   Reply With Quote
Old 05-17-2013, 04:29 PM   #2
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Cat back exhaust systems are bolt on, axle back exhaust systems are not. You can cut it with the right saw and blades.
Old 05-17-2013, 04:31 PM   #3
RJT-SS
RJT-SS's Avatar
Drives: '11 2SS/RS A6
All axle-back exhausts require cutting the stock pipes. The only way to avoid cutting is to install a cat-back because the only place where the exhaust clamps together is at the catalytic converter. A reciprocating saw with a metal blade will work just fine. Measure twice, cut once.
Performance Mods:
Kooks 1-7/8 LTs; Calico coated w/HFCs, Solo Mach XL catback w/J-pipes, VMax TB, C.A.I. Intake, JRE Tune, RX Catch-Can
RJT-SS is offline   Reply With Quote
Old 05-17-2013, 07:12 PM   #4
thahemp
Geek
thahemp's Avatar
Drives: 2012 Black LS3
+1. Get after it!
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1
x = ~x
thahemp is offline   Reply With Quote
Old 05-17-2013, 08:19 PM   #5
jcieutat
Drives: 2013 SS 1LE
Damn it! I am coming from a Mustang where a Corsa axleback was a bolt on. Of course I did install an X pipe with it. I guess I will be cutting this weekend!!!!!
Old 05-17-2013, 08:24 PM   #6
thahemp
Geek
thahemp's Avatar
Just mark it all the way around, or run tape around the pipe so you can keep your cut reasonably straight and that's all there is to it. The catback is ridiculously easy to pop out, so you don't have to do it under the car either.
x = ~x
Old 05-17-2013, 08:24 PM   #7
RJT-SS
RJT-SS's Avatar
Ahhhhhh.....THAT explains it......a Mustang........Since you have now come to your senses.....you are forgiven. Lol.....just kidding of course. Welcome!
So...Southeast Louisiana huh? Whereabouts?
Performance Mods:
Old 05-17-2013, 08:28 PM   #8
jcieutat
Drives: 2013 SS 1LE
Yep, I wanted to see what it felt like on the dark side! I am just putting two and two together that an axleback with an x pipe is a catback! Oh well, it is what it is.
I am in Ponchatoula.
Old 05-17-2013, 08:42 PM   #9
RJT-SS
RJT-SS's Avatar
Yeah, on these cars, right after the cat is a sleeve clamp. That connects the cat to the front of the rest of the exhaust assembly which is an H-pipe, then the resonator (if an L99), then the trash can mufflers & tips. I just finished my header and tune install this week and trying to figure out whether I want to just do a muffler delete (too loud?) or an axleback.
Good luck with the install!
I'm not too far away; Pearl River / Slidell. I have been wanting to get to Hammond for the monthly CCC gathering but always seems to have something else going on....
Performance Mods:
Old 05-17-2013, 09:56 PM   #10
drunKenobi
drunKenobi's Avatar
Drives: 2017 1SS 1LE Krypton Green
Super easy install, did mine a few weeks ago in the driveway. I used a sawzaw with a new blade and it cut through like butter. Took 30 minutes tops. Good luck and enjoy.
drunKenobi is offline   Reply With Quote
Old 05-18-2013, 02:13 PM   #11
jcieutat
Drives: 2013 SS 1LE
Thanks for all the votes of confidence, it was just what I needed. I did the job today in around 30 minutes and could not be happier. The look and sound is awesome compared to the huge cans that come stock. They will be waiting for the garbage man on Tuesday!
Old 05-18-2013, 05:46 PM   #12
RJT-SS
RJT-SS's Avatar
Glad it went well. Pics? Video?
Performance Mods:
Old 05-18-2013, 05:50 PM   #13
thahemp
Geek
thahemp's Avatar
Yep. That's the cost of Camaro5 help. Video!
x = ~x
Old 05-18-2013, 06:42 PM   #14
RJT-SS
RJT-SS's Avatar
I might let him slide if he let's me get a first-hand listen.....
Performance Mods:
