09-15-2014, 09:15 PM | #1 |
American Gold Whisperer
Drives: 2014 White 1LE 2SS/RS/NPP/Rec/Nav Join Date: May 2014
Park or Dismount for winter... 1LE Goodyear facts?
Due to what appears as facts confusion, I ask for some feedback.
My 1LE hibernates in the winter. Fact is the temps around here can have extended temps below freezing for weeks. I do keep a small heater in my garage as I also kennel my dog in the nights in my garage. But I have read alot about the tires and with winter coming I need to resolve facts from fiction. 1... do I need to pull the tires and take them inside? 2... can I leave them garaged on the car knowing the car will not be moved till spring? Or 3... should I keep them on the car but have the car on jackstands to keep the load off them. Quite honestly I get the impression from the goodyear bulletin that all I have to do is park it and not move it. Feedback and opinions please. |
09-15-2014, 09:39 PM | #2 |
Drives: 2014 Camaro 2SS 1LE NPP Join Date: Nov 2013
Nope. There are members here on this forum whose tires have cracked while not being moved. If the temps in your garage are going to drop below 25 degrees - pull them inside.
Personally, I'm going to switch up to Pilot Super Sports as a daily-driving tire as I don't have a garage and park the car outside. |
09-15-2014, 10:53 PM | #3 |
Drives: 23 LT1 / 19 Z06 / after 6 5th gens Join Date: Jan 2014
I picked up a set of 19" wheels and tires from a member on C5 for $450. Cheap price to pay to avoid an "oh sh.." moment come April. The car won't leave the garage, but still I didnt want to take a chance
09-16-2014, 07:54 AM | #4 |
Institutionally Insane
We had the worst winter here in Michigan in years..
1LE parked in unheated garage, tires mounted, sat on concrete from November until May. Only thing I did was 40 psi on all 4 corners. No issues, no cracks..flat spots etc. To each his own.
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspension, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas. What do you say, is it the new Bluesmobile or what?
09-16-2014, 08:08 AM | #5 |
Drives: 2014 2SS 1LE BRM Join Date: May 2014
I am with Banshee on this one. The tread compound used in our tires is not suitable for winter driving. That only means that there will be very limited traction at lower temperatures. I do not believe that lower temperatures are detrimental to the rubber compounds ability to survive.
09-16-2014, 08:18 AM | #6 | |
http://www.camaro5.com/forums/attach...3&d=1359149475 |
09-16-2014, 08:23 AM | #7 | |
Drives: 2014 2SS 1LE Join Date: Sep 2013
My first set cracked... Although the car was stuck on a trailer for 10 days at the rail yard due to frozen hydraulics as the temps frequently saw -30... Also it arrived Saturday evening sat inside until Monday morning when they moved it outside in the high of -28 all day until PDI was done that evening. So I think it has to be extreme conditions but under the right circumstances they will crack
14 2SS RS 1LE Recaro NPP Pat G cam and tune, Trick flow heads Long tube headers catless
09-16-2014, 08:57 AM | #8 | |
Drives: E92 BMW M3 Join Date: Oct 2012
Link to flatstoppers: http://www.amazon.com/Race-Ramps-RR-.../dp/B003ZAGJAM Do not do #3, as that would be very bad for your suspension components.
SOLD - 2013 1LE - Pat G Spec'd Cam, NPP with 1 7/8" Long Tube Headers with High Flow Cats, Intake w/scoop, Ported Throttle Body, and Apex 1.25" Lowering Springs.
J-Rod Built and Matt@FSP Tuned |
09-16-2014, 09:04 AM | #9 |
Drives: 2022 CT4-V Blackwing Join Date: Sep 2013
Amazing. I live in Florida so luckily I don't need to worry about this issue but I think about how poor the traction is with these tires when they are cold. I can only imagine what happens when they are ice cold. I am picturing sneakers on ice.
09-16-2014, 09:11 AM | #10 | |
Drives: 2013 2SS/RS/1LE Join Date: Mar 2013
I can see how extreme cold could a problem though. The stories I've read about them cracking seem to be outside storage where wind chill/gusting could be a factor. I've read the bulletin many times and didn't see wording like "required" to store above 40F.
09-16-2014, 09:14 AM | #11 |
Drives: 2013 Camaro 1LE Join Date: Aug 2013
I am doing this tomorrow and keeping the goodyears for when I sell the car.
2013 Camaro 1LE - SLP TVS2300, TSP 2" Headers, CAI, ADM FCM, NPP, Monster LT1 clutch, MGW flat stick, TSP LS3b cam, PAC springs, S&M Motorsports Tuning, 591 hp on Mustang Dyno
2016 GMC Denali 1500 Bulach Racing Team - Home of the fastest manual powered GM car in the world! |
09-16-2014, 09:44 AM | #12 |
09-16-2014, 09:48 AM | #13 |
This is why i will be installing a heated floor in my garage when I build my house.
Retired United States Army
Bernadette: 2LT/RS, ABM #2041 of 3903 ZL-1 Springs | CAI | Muffler delete | Magnaflow resonator | LED DRL | DRL harness | RX Catch Can | Mini me Cortana: 2015 Harley Davidson Road Glide Special V&H Power Duals Headers & Oversized 450 Raider mufflers | Screamin' Eagle Stage 1 Chisel Extreme intake | Screamin' Eagle Stage 1 programmer | Klock Werks 12" Pro-Touring windscreen Own an Aqua Blue Metallic Camaro? Click here to join us on Facebook and help us in establishing the Aqua Blue Registry to locate all 3903 of these beautiful Camaros! |
09-16-2014, 10:13 AM | #14 |
Drives: 2014 2SS 1LE AGM Join Date: May 2013
what if you wrap the tires in an insulated blanket while being stored in a unheated garage?
I was planning on doing that b/c I doubt I will have 1400 bucks to shell out by Dec for Michelins. |
