06-30-2015, 06:04 AM | #1 |
Exhaust question
Am I holding back power running a 2.5 exhaust. I'm making over 600whp being superchargered. My headers are 2" primarys down to a 2.5 collector and 2.5 all the way out the back. It's straight piped.
Do I need to look into a 3" exhaust or no?
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/ |
06-30-2015, 06:37 AM | #2 |
I can't tell you if you need a 3 inch exhaust system with that level of power. But I can tell you that in my opinion I'd go for a 3 inch cat back. 600hp is a good bit, and you already have 2 inch headers; may as well go for the 3 inch exhaust.
Taco's 2014 SS
Mods: 417 Stroker | CAI | Bo's PTB | Kooks LTs | Flowmaster Outlaw Catback | Night Fury Cam | Powerbond UDP | Apex Catch Can |PRC Ported Heads |FAST 102 Intake |Suspension Crap| Built by J-Rod. |
06-30-2015, 09:40 AM | #3 |
It shouldn't be killing you but you are probably leaving some top end power on the table. Plus 3" sounds better so.....
06-30-2015, 12:50 PM | #4 |
Sounds better how
06-30-2015, 02:29 PM | #5 |
Drives: 2010 Camaro 2SS/RS Join Date: Aug 2012
More air flows through a 3" exhaust than a 2.5" exhaust. Thus, creating more sound. Same goes for putting longtube headers on a car over stock.
2010 Camaro 2SS M6
2" Stainless Power Longtube Headers 3" Full exhaust w/ Off-Road H-Pipe Bo White Ported Throttle Body Hurst Short Throw Shifter Best Time: 12.43 @ 114, 1.99 60' on stock wheels and stock tires Build Thread |
06-30-2015, 04:54 PM | #6 |
06-30-2015, 11:10 PM | #7 |
Drives: 2015 ZL1 Join Date: Jan 2015
All other things being equal, a larger diameter pipe should improve flow and high-RPM performance while a smaller diameter pipe will have a little more gas scavenging and increase low-RPM torque.
That said, I'm not sure that going from 2.5" to 3" will significantly reduce low-RPM torque enough to change driveability significantly and the 3" will, as others have said, be a bit louder with a deeper tone. |
07-01-2015, 07:11 PM | #8 |
I can't find an exhaust system that don't break the bank. I have $700 in my headers and full exhaust.
07-01-2015, 07:42 PM | #9 |
Do a muffler/resonator delete. Cost about $150.
2010 Camaro 2SS M6
07-01-2015, 08:14 PM | #10 |
Homeless Life Chose Me
Drives: LS3 (sold 4/21) Join Date: Nov 2014
He already did that. The whole point of this thread is that he needs a 3inch exhaust
Pity a man in familiar places, who yet feels like a stranger.
07-02-2015, 12:32 PM | #11 | |
In any case, if money is a problem, 1/2 an inch isn't going to make that much of a difference. Nothing noticeable except maybe a little in sound, but that's it. I'd save the money and put it towards something else.
2010 Camaro 2SS M6
