SDTW Custom Wheels & Tires
Old 08-14-2012, 05:18 PM   #1
mike.nite
mike.nite's Avatar
Drives: 2011 2SS L99, 2010 LT RS
NGK TR6 iridium plugs in a n/a cammed car
A friend installed NGK TR6 (V-POWER) iridium plugs in his 2010 SS L99 with just bolt-ons and told me that the difference is huge. He said that the upgrade was well worth the money.
I do have a 2011 SS with aftermarket heads, cam and bolt-ons. (compression 11:1). No F/I.
Will it be worth to upgrade?
mike.nite is offline   Reply With Quote
Old 08-14-2012, 05:59 PM   #2
BrownMan's SS
BrownMan's SS's Avatar
Drives: 2010 Camaro 2SS/RS L99
I also have a l99 with cam and bolt ons. I was actually also recommended these last week. I was also told to space the gap in the spark plugs to 40 thousandths (0.040). I am going to put them in in a couple days
BrownMan's SS is offline   Reply With Quote
Old 08-14-2012, 06:01 PM   #3
RogerBzSS
RogerBzSS's Avatar
Drives: 11 IBM n White 2SS/RS M6
Not to be a smart ass!!
But have you're friend define the HUGE difference!!
I can see and expect the difference being in the wallet
Black CIA -Powder Coated Red Air Scoop - Vmax Ported Throttle Body - Ceramic Coated Dynatek Headers - High Flow Cats out thru factory Cat Back - JRE rough idle cam package - Trunion Upgrade - Valve Springs - Hardened Push rods - 3 bolt timing gear - SLP Under drive pully- Washer bottle relo kit - Hurst Short Throw Shifter with updated pin bushing from C5 member NH-SS - IdealG's improved Master Cylinder - GTO Clutch reservoir - L99 Brake Reservoir - Stainless Braided clutch line - wrapped up with a JRE Tune My SS layed down 462 hp on JRE's Superflow Dyno
RogerBzSS is offline   Reply With Quote
Old 08-14-2012, 06:01 PM   #4
Higgs Boson
in the ZL1 Market
Drives: 2014 C7; 2015 2500HD
waste of money. get some tr5 copper plugs. not kidding. tr6 is too cold anyways.
Higgs Boson is offline   Reply With Quote
Old 08-14-2012, 06:42 PM   #5
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
It's a colder plug, I have them on my 12-1 compression Ls3 stroker in my sig and I would go with the Tr5.
Old 08-14-2012, 07:57 PM   #6
LBV
LBV's Avatar
Drives: G8 GXP manual
Isn't the rule of thumb 1 step colder for each 100 hp gain??
2009 GXP, Manual with Sunroof
Zeta platform, LS3,TR6060 tranny ... ya, it's a 4-dr Camaro!
Borla cat-back, H&R springs, & Sprintbooster & I love it!
LBV is offline   Reply With Quote
Old 08-14-2012, 08:02 PM   #7
Higgs Boson
in the ZL1 Market
yes if cylinder pressure is increased as a result. some cams can lower dynamic compression ratio.
op said bolt ons. that doesn't necessitate colder plugs. nitrous or forced induction and some cams depending on valve events.
Old 08-15-2012, 04:25 PM   #8
mike.nite
mike.nite's Avatar
Okay - With my friends setup (Intake, Headers, Exhaust) the NGK TR6 iridium plugs might seem to be a lil overkill.
But whats with my setup? I have higher compression (11:1), cam and heads. Are they really to cold for my setup?
Old 08-15-2012, 04:58 PM   #9
Higgs Boson
in the ZL1 Market
what cam?
Old 08-15-2012, 05:08 PM   #10
mike.nite
mike.nite's Avatar
Originally Posted by Higgs Boson View Post
what cam?
Livernois 218/229 .600"/.600" 117.5
TSP PRC LS3 250cc CNC Cylinder heads milled 0.040"
Old 08-15-2012, 05:17 PM   #11
Higgs Boson
in the ZL1 Market
you could try it and see. that cam does not have any positive overlap. just put them in, see how they feel at idle and part throttle. check them once in a whole to see if they start fouling.
Old 08-15-2012, 05:59 PM   #12
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
im lookin to do something like this aswell , what plugs do u guys recommend im at 470ish rwhp , lg g6x3 cam and boltons. also what plugs do u recommend with same thing but a 100 to 150 shot . will be doing a shot after about a month. but want to see what u guys think in both cases
check out ky speeds fb page https://www.facebook.com/kyspeed
dekan513 is offline   Reply With Quote
Old 08-15-2012, 06:18 PM   #13
Higgs Boson
in the ZL1 Market
tr6 for the shot.
Old 08-16-2012, 11:00 AM   #14
Agent WD-40
Agent WD-40's Avatar
Drives: 2010 Camaro SS
I took the TR6 plugs out of my car and put the factory plugs back in and I thought the car idled and ran a bit smoother. I didn't notice any gain or loss in power.
Ted Jannetty was the one who recommended I try this. He said he runs factory plugs with all of his bolt on & cam cars.
L99 - 440 RWHP
Livernois 2c Cam & VVT/DOD Delete
Roto-Fab Intake
Stainless Works 1 7/8" Long Tube Headers
Corsa Exhaust
Agent WD-40 is offline   Reply With Quote
