Old 11-18-2017, 10:40 PM   #1
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
Budget Cradle Bushings
Does anyone have the BMR poly rear cradle bushings and how do they work?
I would like the solid ones but cant really afford them.
zz430camaro is offline   Reply With Quote
Old 11-18-2017, 11:46 PM   #2
Crash76
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500
I would just wait till u can get pegasus solids...
399$ vs 179$ ... might get them cheaper from a vender
If i were in your shoes i would wait till finances were a lot better before modding, sounds like your money could be better off saved.
But the bmr inserts fill the gaps in the cradle bushings...
Crash76 is offline   Reply With Quote
Old 11-19-2017, 09:12 AM   #3
DrkPhx
DrkPhx's Avatar
I agree with the above post. Can't beat the quality or price of the Pegasus mounts. While the install isn't that bad; it does take time and it's one of those "do it right, do it once" mods. The solid mounts really tighten up the rear suspension and the increased NVH is minimal.
Old 11-19-2017, 09:17 AM   #4
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Agree with both the solids are awesome and feel you might be disappointed in poly or inserts. I got a set of PFADTs for 400 that a guy had was steal for sure, watch the classifieds while you save. I could be happier with my install car seems to accelerate better as well as handle better. Let me dig around in the shed I might have a set of sneers you can have.
Orange Krush II
Old 11-19-2017, 09:32 AM   #5
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
huh,, hate to be the odd one out but the Prothane inserts made a HUGE difference, easy to install and IMHO very cost effective...the biggest change to the rear was the replacement of the T/A's and bushings...now THAT keeps the rear planted...good luck!
BTW - the Prothane motor mounts added IMHO very little NVH(not that I care) and not only stiffened up the front but also made a nice improvement in shiftin...7k all day...
Old 11-19-2017, 09:56 AM   #6
zz430camaro
Drives: 2015 1LE
Ok, i was just really wondering if the cost of the aluminum was justified, I was really doing the comparison to the one piece poly ones from BMR. Looking at the BTR poly pro version at summit, that poly seemed really hard and it seemed like it would do the job well. I realize the aluminum will not budge but it is double the cost.
Old 11-21-2017, 10:49 AM   #7
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Our Pro Version's are a High Durameter - I don't have failures on these or customers that ever complain
Old 11-21-2017, 03:09 PM   #8
zz430camaro
Drives: 2015 1LE
I think for a street car the BMR ProVersion cradle bushings will work fine and they are only 200 bucks.
Old 11-28-2017, 01:32 AM   #9
LCPLPunk
USA-1
LCPLPunk's Avatar
Drives: 2010 Camaro SS L99
Here is what I used... https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete
LCPLPunk is offline   Reply With Quote
Old 11-30-2017, 01:18 PM   #10
Mills_Bell
Drives: 2013 Camaro SS
Prothane poly here and they are great. There may still be some minor flex, but I could not tell. It handles much better than before.
Mills_Bell is offline   Reply With Quote
Old 12-01-2017, 11:53 PM   #11
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
If you're going through the hassle of it, might as well go with solids. Pegasus is hard to beat for the quality and money.
More to come.
Black_SS10 is offline   Reply With Quote
