07-06-2016, 11:02 PM | #1 |
Engineer
Drives: 2014 Camaro 2SS RS 1LE Join Date: Jun 2015
Anyone use BMR rear springs only? 1LE
I have an all-stock 1LE 14 camaro, and temporarily want to drop the rear mainly for cosmetic purposes. I also want the car to not do anything fishy on the track, I do plan on racing the car.
My future plans will be redoing almost the entire suspension, but for the time being I plan on just getting the best of what i've got. The BMR 1" drop rear springs are 460 ft/lbs, a bit stiffer than the OEM rears. Considering that the rear swaybars in these cars need upgrading to get the car to turn-in a bit better, these springs should create the same effect without upgrading the sway bar? I am not too worried about the spring rates, using the front : rear spring rate ratio, the OEM front + BMR rear seems to fall between some of the competitors, so it does not seem like it will be unbalanced. Anyone have any input on this before I pull the trigger? Also, will I need rear camber bolts to fix the camber in the rear for a 1" drop? |
07-07-2016, 06:05 AM | #2 |
Drives: 2014 SS Convertible Join Date: Jun 2015
You'll need to fix the camber and might not be able to without camber bolts or lower control arms.
More importantly, if you're going to do suspension work do it right. Wait until you can do all the springs/shocks, or both sway bars. Here is my thread for when I redid the suspension. I don't have a 1LE, but I've got a better suspension now http://www.camaro5.com/forums/showthread.php?t=457049
Engine: LSA Conversion, Ported Heads, 1 7/8 headers, VMS 2.5 Cam, Roto Fab intake, ADM Scoop. BMR engine mounts, 3.91
628/525 Suspension: Koni orange, (BMR everything) 1" drop springs, toe rods, trailer arms, non adjustable LCR, FE4 sway bars, sub frame connectors, delrin sub frame bushing and upper control arm bushings. Front bushings. |
07-07-2016, 10:20 AM | #3 | |
2013 Camaro SS1LECTSVZ28
Drives: 2013 AGM 1SS/1LE Join Date: Nov 2012
The 1LE is such a great package from the factory it is hard to improve upon. The "only" reason to lower a 1LE is for looks. My first suggestion is find a set of Pedders rear springs....but those are few and far between at this point. I have often said if I did it again I would use/try BMR 1" in the rear only......That is until I received a long PM from a educated 1LE owner that had problems with the BMR spring in the 1LE as it was designed for the SS and make clanking noises. The issues was never resolved and BMR gave him his money back. You may have better luck than he did. My 1LE required rear camber bolts to bring the rear into spec. I would avoid aftermarket lower control arms as they are not needed. There is a ton of information about the springs and set-up in my build thread in the sig -Matt
07-07-2016, 11:22 AM | #4 | |
Drives: Race Car Join Date: Sep 2009
07-07-2016, 12:18 PM | #5 |
Fair enough, but that is what one of your customers stated happened in a PM to me..I had/have no skin in the game and was recommending your springs on a 1LE to lower the rear only when he PM'd me.
Did BMR have a fitment issue with some 1LE cars? Was there ever a change to the springs? If so an explanation with details behind the issues may be helpful Thank you, Matt
07-07-2016, 02:32 PM | #6 |
Drives: 2015 2SS/RS/1LE Join Date: Jun 2015
I was told the issue had to do more with the 14/15 model years and not the 1LE specifically, but who knows. I think the same person warned me about his experience as well. It was enough to scare me away, right or wrong.
Supposedly BMR did a slight redesign to correct this issue with some of the 14/15's. I heard BMR springs were shorter in length vs other drop springs for the Camaro, and caused them to have possible seating issues. Who knows though as I have also heard plenty of happy BMR customers. I am going to try the Hotchkis springs personally. Fingers crossed... |
07-07-2016, 03:24 PM | #7 | |
07-07-2016, 09:30 PM | #8 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
When did the change occur?
2022 1SS 1LE A10 BCD WCT+PDR2014 1SS 1LE NPP RECARO SIM-SOLD1995 Z28 M6 GSC PGM-SOLD1975 NOVA COUPE 300HP 350 TH350 FLASH RED-SOLD
07-08-2016, 10:28 AM | #9 |
Drives: 2010 2SS/RS M6 Black on Black Join Date: Jan 2010
I have BMR 1" drop springs with 1LE shocks and struts on my 2010 SS and have no noises or problems...except for faster tire wear from faster corner speeds.
Meh
07-08-2016, 01:11 PM | #10 |
07-08-2016, 01:26 PM | #11 |
Have there ever been complaints of noise or fitment issues from the rear springs on the 1LE? If so what was the root cause if it was not the spring itself?
