09-24-2012, 04:48 PM | #1 |
Banned
Drives: 2013 CRT ZL1 Join Date: Sep 2012
CLUNKING NOISE
Probably not the right section to post this in but couldn't find a category for it so here goes...
I have about 4000 miles on my 2012 automatic SS and recently have been hearing a clunking noise when making sharp right hand turns. Best way to describe it a clunking or knocking noise. I pretty much narrowed it down to the front end, I think the driver side front. Anyways I'm bringing it in tomorrow but I thought maybe I'd get a jump start to people's guesses on this? Thanks for the help.. Eric B. |
09-24-2012, 04:54 PM | #2 |
Drives: 2012 Camaro SS L99 Join Date: Apr 2012
I have the same thing its coming from the rear diff or axles. there are a few threads on this issue.
09-24-2012, 04:55 PM | #3 |
Drives: 2012 AGM 2SS Join Date: Feb 2012
Trunk monkey stored incorrectly?
But seriously, most likely it's something with your suspension that isn't interacting with the rest of it incorrectly. |
09-24-2012, 04:58 PM | #4 |
Drives: 2010 2LT...Black Join Date: Jul 2012
I have heard that as well and I believe that it might be the books and stuff in the glove compartment. I know it kind of sounds crazy but I cant imagine what else it could be.
09-24-2012, 05:00 PM | #5 |
Banned
09-24-2012, 05:01 PM | #6 |
Zach
Drives: 10 SIM 1LT, 66 F100 Join Date: Jul 2012
If its when you turn its power steering problems. Check the fluid under the engine covor (unless a V8 is different there should be one) or rack and pinion, or maybe even a wheel bearing. Take it to the dealer and have them check it out. It's under warranty
2010 1LT
66 Ford F100 Camaro rep for Az ModRod Productions, havent liked us on Facebook? check it out! http://www.facebook.com/#!/ModRodProductions |
09-24-2012, 05:06 PM | #7 |
Drives: 2019 ZL1 A10 Join Date: Feb 2011
I had the issue coming from the passenger side rear of my car... took it to the dealer, they replaced the shock... 30 feet after pulling away, it was back. They then said "oh, it could be the bushings for xxx" (I don't remember what for, hence the x's). So they replaced them, noise is back. If anyone finds out what the clunk is with certainty, for the love of God, please post it.... it's driving me nuts.
09-24-2012, 05:09 PM | #8 |
Zach
If its a strut lift the hood, stand to the side and push up and down on the car if you feel or hear a clink the strut/spring is bad. If not its could be a wheel bearing or the rack and pinion if it has one
2010 1LT
09-24-2012, 06:03 PM | #9 |
Drives: 2012 SS Join Date: Mar 2012
Mine does it from the driver left rear.
If you are in a parking lot doing a tight circle you can hear it constant.
Thanks
T |
09-24-2012, 06:11 PM | #10 |
09-24-2012, 09:23 PM | #11 |
Banned
Thanks for all the replys... mine is definitely coming from the front somewhere and it only happens on sharp right hand turns not left. It almost sounds like something is broken, who knows maybe bushing, tie rod , bearing etc....
Well hopefully they can identify it tomorrow and not try and blame any mods I have, LOL......... I will post back tomorrow afternoon and let you guys know how I make out... |
09-24-2012, 09:34 PM | #12 |
Drives: '21 Bronco OBX/'18 Jeep GC Altitude Join Date: Jul 2008
I look forward to hearing the result. I think I have a wheel bearing going out on mine, I heard a loud squealing when turning right and I also get a little play in the steering when getting up above 60mph.
I'll be having it checked out next time I am over at the dealer.
Order Placed: 04/30/22
Order Accepted: 10/18/22 TPW: 11/07/22 Built: 11/18/22 VIN received: 11/19/22 On a Train: 02/27/23 ETA: TBD 2023 Camaro 2SS Convertible/M6/Shadow Grey Metallic/Adrenaline Red Interior/Carbon Flash Wheels/NPP Last edited by CUPRA; 09-25-2012 at 01:17 PM. |
09-24-2012, 09:50 PM | #13 |
Rollin' The Lunchbox
Drives: 2012 Camaro Ashen Grey Join Date: Aug 2012
I'm picking my car up tomorrow for the torque converter and Clunk in the rear repair...my dealer said the clunk is fixed ill post what the result is tomorrow...
Sent from the front seat of the Amberlamps! |
09-24-2012, 10:33 PM | #14 |
Sarcasm loading --------
i think there is a service bulletin on this.
"The salesman actually told me to stop getting it sideways during the test drive"
2018 MBM ZL1 1LE - Stock 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
