08-18-2012, 03:54 PM | #1 |
Drives: A Z28 and A Grand Prix Join Date: Apr 2009
Clunking Noise
on my way home today i noticed a clunking noise coming from the front of the car on the passenger side. It seems to be more noticable at slower speeds but when you turn the wheel it almost feels like something is broken or extremely loose. I crawled underneath and pulled on and wiggled everything i could reach but everything was solid. Any suggestions?
2003 Pontiac Grand Prix GT
K&N Cold Air SLP Cat Back Exhaust 2000 Chevrolet Camaro Z28 Flowmaster Exhaust SLP Lid 10 spoke SS Rims |
08-18-2012, 04:05 PM | #2 |
strut tower mount, ball joint? if you jack up the front of the car and grab the tire and try wiggle it around some you will know netter what it might be. if the bottom of the wheel pulls out/pushes in some then probably a ball joint. you should also be able to hear some minor clunking when you do this.
does it happen when braking? front end shake at all when braking? |
08-18-2012, 05:25 PM | #3 |
it does happen when I'm braking. the front end doesn't shake
Posted from Camaro5.com App for Android
08-19-2012, 05:04 PM | #4 |
jacked up the car and the wiggled the tire around and didn't hear anything. tire was solid with little play. I noticed after that the noise was gone.
10-01-2012, 12:21 PM | #5 |
Drives: 2012 2LT/RS Join Date: Oct 2011
Exactly what I am experiencing as well. Even just had the struts, sway bar and end links replaced.
If they put the car in the air, I'm good for the drive home(-ish). Then day or two later, it's back. Really frustrating. |
Thread Tools | |
