03-29-2014, 02:07 PM | #1 |
rollerskates on calipers 1LE
hi guys, would like to know if gm still has the rollerskates installed -2014-on the front calipers of your 1LE.
i think it was installed there for vibration? hope it's all gone ,to make a much cleaner look inside the wheel since the caliper is red... thanks |
03-29-2014, 02:25 PM | #2 |
Drives: 14 1SS Camaro 1LE, NPP, Recaros Join Date: Nov 2013
they were on mine, built before the winter shutdown
03-29-2014, 03:22 PM | #3 |
Drives: 2014 1LE Camaro 2$$ Join Date: Mar 2014
Late 2013 build mine are still on there... they help reduce brake moan and harmonics don't take them off
03-29-2014, 03:23 PM | #4 |
Drives: 2014 Z51 Corvette Join Date: Apr 2011
My 14' has them.
03-29-2014, 03:42 PM | #5 |
Drives: 2013 1LE Join Date: May 2013
There not on the calipers, there on the pads.
03-29-2014, 04:03 PM | #6 |
Redonkulous
Drives: Camaro Join Date: Feb 2014
03-29-2014, 04:11 PM | #7 |
No regrets the red one!
So the roller skates are only needed on the stock brake pads? If I replace the stock pads with Hawke Ceramic pads, they will be gone?
03-29-2014, 06:12 PM | #8 |
ITCRNRS
Drives: 2018 ZL1 1LE Join Date: Jun 2012
Come with the stock pads im planning on cutting them off when our 1LE comes in just as I did when I brembo swapped our current, if nothing else just looks better
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap |
03-29-2014, 06:54 PM | #9 |
03-29-2014, 10:03 PM | #10 |
that's a good thing to know. it's even better ,that's only part of the pads. still it's sad that it's still on the newer ones.. i guess gm's engineers bailed out---//more lack of $$ do to more research/test--- of looking for something better than this solution..
Thanks for the info. much appreciated |
03-30-2014, 08:24 AM | #11 |
Drives: 2013 2SS/RS/1LE Join Date: Mar 2013
Sure you want to do that? I thought they were there to prevent brake squeal.
