Old 08-04-2017, 07:35 PM   #1
Barry_Allen
Drives: 2014 L99 Camaro SS
After Market Torque Converter
Are any of you running an after market torque converter after installing a new cam on your auto SS? If so what brand do y'all recommend for running the vvt-4 cam that TSP offers? Also any reccomendations for parts to go along with this upgrade would be greatly appreciated.
I am already running with K&N Blackhawk intake with Speed Engineering Long tubes and an SCT tuner.
Barry_Allen is offline   Reply With Quote
Old 08-04-2017, 09:12 PM   #2
PostNup
CAR-DASHIAN
Drives: 2015 Ashen Gray Metallic 2SS/RS L99
SCT Tuner is nowhere near set up to handle a stage 4 cam, unless the tuner sent you a tune to load into the SCT.
That being said, TSP told me that for a VVT4 cam they would recommend a 3600-3800 stall converter.
HTH
PERFORMANCE: ColdAirInductions CAI, ADM Race Scoop, Cordes Performance Racing Ported TB/IM/Custom VVT Cam, WFO Milled Heads, Stainless Power 1 7/8" LT/3" HFCs, JBA 3" Comp. Cat-Back, Taylor 10.4mm Plug Wires, Tim King Performance Stage 3 6L80, Circle D Billet 3600 Stall, Nic D ECM/TCM Tune, - 458rwhp/413rwtq (prior to PIM), Forgestar F14 (F)18" / (R)17" Rims.
SUSPENSION: Z/28 Rear UCA Bushings, Carlyle Racing LCA/TA, BMR Adj. Toe Rods/Xtreme Anti-Roll Bar, Justice Pete Castor Locks/Radius Rod Inserts, Pegasus Billet Rear Cradle Bushings, Mickey Thompson Street SS II 305/45/17 tires.
PostNup is offline   Reply With Quote
Old 08-04-2017, 09:25 PM   #3
brick59
Sucker Punch
brick59's Avatar
Drives: 2013 Black ZL1, 2007 Silverado LTZ
As far brand I recommend Circle D, call them and tell them your setup and your goals they will help you get the correct converter.
427 Dart SHP Pro LS Block, Callies Magnum Crank, Callies Ultra I Beam Rods, Diamond Pistons, AGP twin Turbos 6865, Mast heads, Cam Motion LLR cam, Morel tie bar lifters, Crower roller rockers, NW 103MM TB, ID2600 XDS, Fore Triple, DSX, E85, ARH Turbo Headers, Corsa, Jakes stage 5 4L80, Circle D, RPM Roll Bar, BMR, Carlyle Racing 15" conversion kit.
brick59 is offline   Reply With Quote
Old 08-05-2017, 06:55 AM   #4
Barry_Allen
As I understand, any tuning shops using SCT Livewire can load their custom tune onto the SCT Tuner.
Old 08-05-2017, 08:06 AM   #5
2010reddevil
Drives: 2010 Camaro 2SS Victory Red 6M
Why is everyone so dead set on Circle D? I know they make great converters, but so do Precision Industries and Yank. Your stall speed should be 500rpm below peak tq. If it'sike most LSx engines with a meaty cam, then your tq peak is gonna be in the area of 4800+ rpm. So you should have a 4000 to 4200 stall. Any of these 3 brands listed will be a great upgrade. Make sure you get a triple disc lockup model to enable wot lockup to increase your mph on the big end.
2011 2SS 6A Red Jewel Metallic, Vararam Tune CAI, Magnaflow 3" Competition c/b, Speed Engineering 1-7/8 LT's, Circle D 5C, M/T 275/40R20 S/S, HPTuners tune by Ryan@GPI
12.3 @ 112 ACM as of 12/22/19
Gone on 12/28/19 R I P
2010 2SS 6M Victory Red/Black (old ride)
CAI intake, Speed Engineering 1 7/8" LT's, X4 base tune, Flowmaster Outlaw axle-back.
12.6 @ 115 SAR as of 9/19/15
Gone but never forgotten.
2010reddevil is offline   Reply With Quote
Old 08-05-2017, 09:05 AM   #6
SynergyGreenSS
SynergyGreenSS's Avatar
Drives: 2011 2SS
I have a yank 3200SS that I'm very happy with. Very drivable
2011 SS L99
LSA Supercharger, BTR Stage 3 PDS Cam, Yank 3200SS, Weapon X Stage 2 intake, LSA Heads, Flex Fuel, Ported throttle body, Speed Engineering Headers, NOWEEDS, ZL1 fuel pump, DSX AUX Pump, ID-1050X injectors, 3” pipe to NPP mufflers, 3.91 gears
SynergyGreenSS is offline   Reply With Quote
Old 08-05-2017, 09:57 AM   #7
rontammy0
Drives: 2011 2SS/ RS INFERNO ORANGE L99
I have a 3200 Cirlce D stall for my set up. Works great. But like Reddevil said there are a few different choices.
rontammy0 is offline   Reply With Quote
Old 08-05-2017, 02:57 PM   #8
jc615
jc615's Avatar
Drives: Camaro and Sierra
Vvt4 and circle d 1e
Previously had FTI 3200 on tsp vvt2. Both worked great but circle d converters are putting down some good 60' times
jc615 is offline   Reply With Quote
Old 08-09-2017, 12:26 AM   #9
SSeniorMoment
Drives: 2010 2SS/RS LS3 A6 IOM
Another Circle D here, 3600 stall and SFI flexplate w/ARP bolts. Answered Brian's questions and they built one for the Camaro, great company to do business with. I ditched the VVT and went with a 3 bolt Cam Motion low lash solid roller cam (235/244 0.64x/0.62z) with Jesel shaft mounted rockers, very quiet valvetrain noise and this engine really likes to spin, no loss in low end torque compared with factory VVT.
SSeniorMoment is offline   Reply With Quote
Old 08-09-2017, 02:07 AM   #10
LCPLPunk
USA-1
LCPLPunk's Avatar
Drives: 2010 Camaro SS L99
VVT cams make better power from what I hear and earlier too.. :P
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete
LCPLPunk is offline   Reply With Quote
Old 08-09-2017, 02:22 AM   #11
2010reddevil
VVT cams in general make good power, but they're not gonna make the power a LLSR will. If the tq peak is astronomically highike most LSx cammed engines are, then a 4000+ stall will be ideal. Really just depends though on the entire setup. As stated, call any of the big 3, Yank, Precision Industries or Circle D, give them your entire rundown and they will build a converter suited for you. Make sure you get a triple disc lock up style so you can engage the lock on 4th Wot.
Old 08-09-2017, 08:08 AM   #12
WoodBoss
"Old School"
Drives: 2010 2SS L99
When I get a converter I'm going with Circle D.
WoodBoss is offline   Reply With Quote
