Old 10-02-2015, 10:04 PM   #1
2k132LS
Drives: 2013 2LS
help installing AFR gauge
Instructions say to tap in to oxygen sensor signal wire? Does anyone know which one it is??? Thanks.
2k132LS is offline   Reply With Quote
Old 10-02-2015, 10:19 PM   #2
LSX Camaro
Master ASE, GM, LSX Tech.
LSX Camaro's Avatar
Drives: 2010 Camaro SS
What brand of gauge? The gauge should have it's own dedicated sensor. There is a big difference in a AFR sensor and a O2 sensor.
2010 2SSRS A6, Custom Pat G. Cam, WCCH Cylinder Heads, Kooks Headers/Exhaust, BTR Valvetrain, Fluidampr 25% UDP, All Engine ARP bolts, Flex-a-lite radiator/Trans cooler, Yank converter, PFADT Suspension, ADM Race Intake/Scoop, Torq tow hook, CFD auto shifter, Dynojet AFR gauge, Aeroforce scan gauge, Brake Performance rotors/pads
Prothane bushings, ZL1 wheels, spoiler, Z/28 wickerbill, 1LE Aero/Suspension Package, Anderson Composites COPO Carbon Fiber Hood, LED lighting, Elite Catch Can, Improved Racing oil pan baffle, crank scraper, windage tray
480 RWHP 452 RWTQ + Nitrous Express 150 Shot
LSX Camaro is offline   Reply With Quote
Old 10-03-2015, 05:32 AM   #3
2k132LS
Drives: 2013 2LS
It is a glowshit gauge.
Old 10-03-2015, 01:05 PM   #4
hunterv6
Always bet on Black
hunterv6's Avatar
Drives: 2011 turbo LS, 2012 f 150,
Return it. They have two different types the one you have is for show. I also have glow shift gauges and if you want accuracy that is not going to help you.
Sent from my iPad using Tapatalk
<font color=#0066cc>http://www.camaro5.com/forums/showthread.php?t=283263</font>
hunterv6 is offline   Reply With Quote
Old 10-03-2015, 10:44 PM   #5
VTSummit
Consistently inconsistent
Drives: 2015 2LT Summit White
If you're doing it just to have a gauge that looks cool- that's fine. If you want one to use to watch your ratio- get a wideband with its own wideband sensor to install in the exhaust.
If you just want to hook to the narrow band original o2 sensors, I have the wiring diagram on the desk in my office- I'll post the information when I get back to work.
Thanks to MRR, I have some SWEET wheels! Thank you!
2015 2LT Ported TB, Ported intake, JACFAB intake spacer, Borla exhaust, IPF 91 tune, Complete 1/LE suspension, Brembo brakes, Goodridge lines, Elite catch can, CAI with Thermo-wrap, 275/40-20 x 10's all around, Z/28 spoiler, GM splitter, Alpine/Polk stereo with AudiControl interface.
VTSummit is offline   Reply With Quote
