07-05-2014, 02:09 PM | #1 |
Drives: still looking Join Date: Jun 2013
Braking issues!
I have a 2010 SS/RS supercharged/meth DD auto with 540 hp at the rear wheels.
From a rolling start or on the highway i can hit 150 mph in a blink of an eye! but the stopping power is not that great, it's a pig to slow down. is there a quick fix without breaking the bank? like pads/rotor upgrade, that's about as far as i'm willing to go thank you in advance and have a nice day! |
07-05-2014, 03:36 PM | #2 |
Drives: 2010 2ss red LS3 Join Date: Aug 2011
ZL1/CTS-V Brake kit. If you need more add track pads to them. Stainless steel lines are a plus. There are Threads in this forum on these upgrades.
07-05-2014, 07:12 PM | #3 |
Drives: 14 1SS Camaro 1LE, NPP, Recaros Join Date: Nov 2013
if you are not tracking @ a road course, pretty sure a good race pad up front will be enough. Repeated 150 to 50 braking multiple times in minutes will take more like adding brake ducts and or upgrading like mentioned to CTSV/ZL1 fronts
07-05-2014, 07:38 PM | #4 |
Drives: FOR SALE! Bumblebee 1 of 1 Join Date: May 2010
Like speed, braking 4,000lbs fast is just a question of money. How fast do you need to stop every day from 150mph? Police have been the best brakes out there to date. Any time I exceeded the speed limit I only had to coast down to 65mph.
My 1 of 1 Bumblebee: Paint=House of Kolor Sunrise. Shaved door handles and concept handles added. Shark fin removed, concept mirrors, Showstoppers concept LED side marker lights. Wiper blades removed, muffler delete, and Range AFM disable. BMR springs lowered 1" rear and 1.4" front and added Eibach wheel spacers - 20mm rear and 25mm front.
07-06-2014, 06:25 AM | #5 | |
I don't track the car, just take it out here and there, car has 6,000 miles. Thanks again |
07-06-2014, 09:24 AM | #6 |
My thinking; When Chevy added 150hp to the camaro SS, what did they do? They put on CTS-V brakes! Why? More HP needs more brakes. Standard automotive engineering practice. Just my $0.02
07-06-2014, 09:51 AM | #7 | |
I was just looking for an easy fix or a little help for my braking with out spending big bucks... Thanks |
07-06-2014, 10:25 AM | #8 | |
waiting at the tree
Drives: SIM 2010 2SS/RS A6 Join Date: Apr 2013
If they don't work out the CTSV front brakes would be about a $1200 upgrade.
2010 2SS/RS A6 ZL1 Rims
60ft 2.03 13.08 at 107.82 (4/28) 2009 Pontiac G8 3.6L the DD |
07-06-2014, 12:18 PM | #9 | |
Drives: '12 2LT Convertible Join Date: Mar 2012
Mods: GM Locking Gas Cap, RS License Plate Frame, SS Brembos, ZL1 FrontEnd, 14/15 Convertible Top
07-06-2014, 07:26 PM | #10 |
Camaro 5 Muscle
Change the brake lines to stainless with Castrol synthec fluid and try Carbotech brake pads AX6 you will not be disappointed!!!!!!!! Listen I tried all the rest and like i said you will not be disappointed. Just keep in mine that all performance brake pads squeal with light brake pressure.
Mods: Air Raid C.A.I., Custom Ported/Polished Throttle Body, Kooks 1 7/8 Headers, Dyno Tuned , LPE 3.91 Gears, BMR Differential Bushings, R/X Oil Catch Can, X-Pipe, Borla Exhaust, MGW Shifter, Hawk-HPS, SS brake lines, BMR front & rear sway bars, BMR rear sway bar end links, Pedders front radius rod bushings, Spohn front sway bar end links, BMR rack/pinion bushing, BMR Coils 1" drop, BMR Trailing Arm, BMR Toe Rods, Pedders Sub-Frame bushings, BMR Sub-frame Connectors, BMR Driveshaft Tunnel Braces, GM Strut tower brace, custom painted bowties
07-07-2014, 12:27 AM | #11 |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
what 130R says.........
if ABS is cycling and you are not boiling your fluid, tires are the limiting factor. increase the friction between the car and the road.........change tires
07-07-2014, 11:50 AM | #12 |
Drives: His Wife Crazy Join Date: Jan 2008
Try going with a set of Hawk HP+ Pads, i think you will like them.
They stop a ton better than the stock pads do, they handle the heat a lot better too. The down side is they squeak more, and make more dust. |
07-07-2014, 06:58 PM | #13 |
+1, the 6 pot brakes offer a greater swept area of braking, larger rotor/pads, so they offset more heat and resist fade. Cars taken to the track usually have wider/stickier tires so the ABS threshold increases as well. Regular street tires are just going to kick off ABS earlier.
07-07-2014, 11:33 PM | #14 | |
Drives: 2013 2SS 1LE NPP GBE Join Date: Sep 2012
The hawks squeaked a lot which wasn't an issue for me. The problem was that after track days they screeched without applying the brakes.
Thread Tools | |
