Old 04-06-2012, 10:58 PM   #1
ztsmith86
ztsmith86's Avatar
Drives: 2010 Camaro 2SS/RS
Help Stripped Crank Snout Threads
So I was installing my Harmonic Balancer and I won't go into the details, but I have completely stripped out all my threads in my crank snout. There is no material left to even re-thread the M16 threads. Does anybody have any suggestions? I have a few ideas myself, but I really need suggestions. This is the last things before my engine install is complete. Thanks for any help .... I'm already down in the dumps about this :(
2010 Camaro 2SS/RS LS3 Inferno Metallic
TSP 1 7/8" Long Tube Headers 304 SS MagnaFlow 2.5 Street Series Catback Exhaust K&N Cold Air Intake Comp Cams Camshaft227/235 .639"/.646"114LSA+2.5 REV 2.165 Hollow Stem Stainless Steel Valves Manley1.59 Stainless Steel Exhaust Valves GM LS7 Hydraulic Lifter Kit Katech CR-5 Timing Chain Manley Hardened Pushrods Comp Cams LSX Rocker Arm Trunion Kit A.I.R. Ported Cylinder Heads Catalytic Converter Delete
ztsmith86 is offline   Reply With Quote
Old 04-07-2012, 06:40 AM   #2
KARBON
KARBON's Avatar
Drives: 2010 CAMARO 850 RWHP/733 RWTQ
Helicoil
*Night Fury
*Vortec YSI
*Alky Meth
*RPM TH400 with Brake
*Precision 3600 Converter
*850 RWHP/733 RWTQ
KARBON is offline   Reply With Quote
Old 04-07-2012, 06:54 AM   #3
toml_pa
ʇuɐıʌǝp lɐıɔos
Drives: 2011 2SS/RS LS3/M6
You have 2 choices, replace the crankshaft or repair the threads. Obviously the first choice is a last resort option. So the question is how to fix the threads. The only way I know of is with HeliCoil Screw Thread Inserts.
You will have to have access to be able to drill the damaged threads out so hopefully the engine is not in the car yet. If it is and you don't have clearance for a drill, you might be able to loosen motor mounts and lift it up enough. Of course the front fascia and radiator would have to be removed. The hardest part will be drilling the hole straight and hand taping the hole for the helicoil. The only other problem I see is that helicoils are usually about 1.5 times their diameter long which means you will only have about 1" of threads. I am not sure how deep the original threads are but isn't the crank bolt fairly long? You might be able to get longer ones or use 2 and stack them. If you know or can find any machinists that have experience with helicoils it would be a good idea to explain your situation and get some advice or better yet pay a machinist to do it. Hope this helps.
toml_pa is offline   Reply With Quote
Old 04-07-2012, 10:10 AM   #4
ztsmith86
ztsmith86's Avatar
Ya my engine all put together in my car
Old 04-07-2012, 11:08 AM   #5
grocerygetter
instigator
grocerygetter's Avatar
Drives: 2020 6.2 Trail Boss, 2022 XC90
I would guess stock crank? If so, helicoil and I personally would pin it to make sure the accessories wouldn't work the threads out off the pulley. But an honest question, will a helicoil hold the kind of torque you need to put on that bolt?
-John S.
Old 04-07-2012, 11:17 AM   #6
94guy
Drives: 99 Camaro; 2010 Camaro 2SS/RS
man that sucks
94guy is offline   Reply With Quote
Old 04-07-2012, 11:48 AM   #7
ztsmith86
ztsmith86's Avatar
Is the stock crank forged, rolled, or cast?
Old 04-07-2012, 11:51 AM   #8
toml_pa
ʇuɐıʌǝp lɐıɔos
I would say yes. The ones I have used were stainless steel as are the ones in the link above. I would be more worried about the new threads in the crank that the helicoil screws into or the threads on the bolt. That is why I suggested trying to get longer helicoils or seeing if it is possible stack them. I wouldn't try torquing it with only 1" of threads. Like you said, pinning or even double pinning it is a real good idea.
Old 04-07-2012, 12:26 PM   #9
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
Pretty sure it's iron.
MODS:
Old 04-07-2012, 12:36 PM   #10
blake-b
blake-b's Avatar
Drives: 2009 ZR1
A quick google search says helicoils can be stacked
Old 04-07-2012, 12:47 PM   #11
zarenski
Drives: 2010 2ss
I not sure how much material you have to work with but can you drill and tap to the next size larger and get a new bolt? The helicoil would make me nervous.
zarenski is offline   Reply With Quote
Old 04-07-2012, 01:04 PM   #12
Eric Baker
Drives: Black/Black 2SS/RS 6M
Yeah I would drill it and tap it to like an 18mm or something, then get a nice bolt from ARP. I wouldn't trust a helicoil for the 240+ftlb the bolt gets torqued to.
To do it in the car won't be bad. Once you remove the bumper, radiator, and move the A/C condenser out of the way, you have great access to the front of the crank.
Eric Baker is offline   Reply With Quote
Old 04-07-2012, 05:19 PM   #13
sschevybear11
sschevybear11's Avatar
Drives: 2011 Black 1SS
helicoil will work and don't stack them. I always understood thread depth won't be any stronger then the diameter of the bolt width. You could use a threaded insert to be sure but you have to drill it out pretty big and may weaken the crank snout to much.
2011 Black 1SS M6 12.75@110.91 bone stock
Now: Coated Dynatech LT's/!Cats/Hurst Shifter/Roto-fab/SLP SS badges/JRE 415HP Tune, Scoop & Washer Relocation Bottle,Hurst Stunner 20X9 Wheels, Moroso Catch Can, ASP pulley, Magnaflow X-pipe, GTO remote clutch reservoir
1989 Silver 5.0 Mustang LX Coupe
1999 Pewter Tahoe LT
2011 Blue Camry SE
sschevybear11 is offline   Reply With Quote
Old 04-07-2012, 06:59 PM   #14
ztsmith86
ztsmith86's Avatar
I've heard the heli coils are really hard to install. The snout has a blind hole .... The threaded part is 3 inches deep inside the blind hole
Who's tired of Z28 threads, lol? radz28 Camaro ZL1 Forum - ZL1 Specific Topics 40 11-13-2009 01:32 PM
For those that are having to pull the crank pulley off. ThunderSS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 19 11-06-2009 02:53 PM
Don't Like Camaro, Trading in Threads... Banshee 5th Gen Camaro SS LS LT General Discussions 42 10-21-2009 10:18 AM
Official Color Threads for Interiors???? blazzin1 Site Related Announcements / Suggestions / Feedback / Questions 1 03-13-2009 09:20 PM
CLOSING THREADS infernoinandout Off-topic Discussions 5 02-11-2009 08:35 AM
