06-27-2011, 12:30 AM | #1 |
Help !How to replace seatbelt?
HI,
Could someone please instruct me how to change the seatbelt? i know i have to unscrew the bottom part but what about the top? It seems like i have to take the whole thing apart since the seatbelt is hidden in side . please see the sample picture . |
06-28-2011, 05:02 PM | #2 |
Any help!?
06-28-2011, 05:53 PM | #3 |
QATAR 2022
Drives: black cts-V coupe a6 Join Date: Apr 2010
i wish i can help but i can't
but i would really want to know why do you want to change your seat belt ? |
06-28-2011, 07:10 PM | #4 |
Banned
Drives: 2015 Camaro 1LT Join Date: May 2010
1.You have to disable the SIR before you remove the seat belt.
2.Unclip the top plastic cover seat belt, remove the 1 Torx bolt T50-T55-T60 size. 3.Pull the trim panel away and there are 2 more Torx bolts to remove. DAVE |
06-28-2011, 07:55 PM | #5 |
Drives: 2012 Camaro 2SS Join Date: Sep 2010
Take a look at this http://www.camaro5.com/forums/showth...peaker+install If you look at the first five photos this will show you how to get to the seatbelts.
Hope this helps. Mark |
Similar Threads | ||||
Random seatbelt chime | JSC81 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 7 | 06-16-2011 11:14 AM |
Seatbelt pads | Dailtile11 | Cosmetics and Lighting Modification Discussions | 3 | 04-06-2011 09:30 AM |
Got a flat: If replacing one tire, should I replace both? | Arachnyd | Wheels and Tires Talk Sponsored by The Tire Rack | 7 | 11-30-2010 08:53 PM |
Do I need to replace the regulator? | White_Knuckle_Tight | 4th Generation Camaros | 3 | 02-06-2010 01:00 AM |
Replace Bowtie with SS | AhX | Cosmetics and Lighting Modification Discussions | 3 | 09-02-2009 09:50 AM |
