Old 06-10-2015, 09:38 AM   #1
mrohitredd
Drives: 2LT_6Speed_RS
23000 Miles - MAINTENANCE
Hey Guys,
Bought mine new in 2012 December. V6 - Manual Transmission, 23000 Miles.
I have just been doing Engine Oil Changes & Recently did a Rear Axle Fluid Change. Cabin Air Filter this week.
1. Did i miss any maintenance ?
2. Manual Transmission Fluid - When do i first do it & how often there after (which one would you suggest?) ?
3. Do i put grease or some kind of fluids on suspensions, tie rods etc ?
Following the Manufacturers Manual, i got confused & did the Rear Axle Fluid change very late ... Don't want to be in such situation again...
Appreciate your input.
2013 Camaro 2LT - White with Inferno Orange stripe with Inferno Orange Interiors - Airaid Intake - Magnaflow 2.5" Street Series Cat-Back Exhaust
2009 Harley Davidson V Rod Muscle - Black - Vance and Hinse Competition Series Slip Ons & Fuelpack - K&N Filter
2013 BMW X5 35d - Platinum Grey with Oyster Interiors - Running Board - Vossen VFS1 20" Staggered Rims
mrohitredd is offline   Reply With Quote
Old 06-10-2015, 10:12 AM   #2
Destructo09
Drives: 2010 CGM Camaro 2SS/LS3
If I remember correctly, none of the front suspension components have lube points.
I haven't even changed the cabin air filter on mine yet, and I just turned 50k miles. I have changed the transmission fluid and differential fluid though, it probably had never been done.
There's not really a lot of things to do until you start getting to 100k miles plus, the coolant is 5 yrs/120k miles. I think the manual transmission fluid probably states like 100k miles but I would probably change it around 50k, or the manual might even say it's not a service item.
Modern cars really don't have much to do other than oil changes and just keeping an eye on stuff like brake pads and filters.
2010 2SS
BMR 1" Springs
Koni Orange struts/shocks
1LE rear sway bar
SRP Racing Pedals
Hurst Billet short shifter
Square tire/wheel setup
Elite Engineering Catch Can
Stainless Power longtubes/highflow cats
K&N Typhoon CAI
RPM Motorsports of Garner, NC dyno tune (421 RWHP)
Destructo09 is offline   Reply With Quote
Old 06-10-2015, 11:22 AM   #3
mrohitredd
ok... so im good for now, right ?
Old 06-10-2015, 12:27 PM   #4
L&M CAMARO 6
L&M CAMARO 6's Avatar
Drives: Just a fan for now
Have you flushed the brake fulid? I like to do a brake fluid flush and change every two years. As it absorbs water and the boiling point goes down.
L&M CAMARO 6 is offline   Reply With Quote
Old 06-10-2015, 12:35 PM   #5
mrohitredd
Never did that.. Will add it to my list... Thanq
