Old 04-22-2018, 09:31 PM   #1
Ishin
Ishin's Avatar
Drives: 2012 Camaro 1LT RS
20x9.5 wheel on front going to be an issue?
Posted this in the tire section, but I'm not sure if it gets much traffic sooo
So I have decided to buy some of the OE Zl1 replicas, I have a V6 with the RS package.
https://www.oewheelsllc.com/20-Fits-...Black-20x9-5-2
But they told me the 20x9.5 would rub on the fronts and I need spacers.
So this has me all confused even though I have been reading on the web about this.
So couple of questions;
has anyone put 20x9.5 on their fronts and does it rub?
if not any idea what size spacers would I need?
and would I also have to put spacers on the back also?
thanks for the help guys.
Rotofab CAI, Vitesse Throttle Controller, Dynomax VT Axelback
Ishin is offline   Reply With Quote
Old 04-22-2018, 09:39 PM   #2
Synner
Drives: cars
It all depends on offset, you can fit far more than 9.5" with the correct offset.
Old 04-23-2018, 08:44 AM   #3
SabotAndHeat
SabotAndHeat's Avatar
Drives: 2010 Camaro
Hey brother, I got ZL1 replicas for my 2SS...20x10’s in the front....20x11’s in the back.
They fit great and look great. No rubbing at all. I would suspect that dropping the suspension may create rubbing issues, depending on your tires.
My offsets are 23mm for the front and 43mm for the back.
Note: I’m sure it’s obvious, but they are staggered.
SabotAndHeat is offline   Reply With Quote
Old 04-23-2018, 09:12 AM   #4
Ishin
Ishin's Avatar
Well I was wanting to do 275/40 20's all around but they said the fronts would rub. Im not lowered and I dont mind having to buy spacers if needed, just not sure what sizes I need to buy and if I only have to get spacers for the front.
Old 04-23-2018, 09:53 AM   #5
pnwdan
pnwdan's Avatar
Drives: 2014 2SS/RS
I am running 20x9.5 +35 offset with 275s in the front
20x11 +40 offset with 305s in the rear.
I am lowered with Hotchkis 1.5" drop springs.
Not one time have I ever had a rub.
2014 2SS/RS LS3/M6
pnwdan is offline   Reply With Quote
Old 04-23-2018, 10:01 AM   #6
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: 2023 ZL1 Sharkskin
if you are not lowered, you should not have any issue with 275/40's. I am lowered and considering 275/40's for the front, but with my HPDE, there is a concern of rubbing and may need to drop to a 285/35 tire instead.
