#Camaro6
Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > V8 LT1 Engine, Exhaust, and Bolt-Ons
Old 09-03-2019, 12:54 PM   #1
TRZ06
TRZ06's Avatar
Drives: 22' Porsche PDK GT4
Tuning on a stock car worth it??
Obviously I know I won't gain much in the HP / TQ department, but I'm talking about more of driveability and having a little less aggressive timing pull tables or rich conditions.
Would it deliver a more crisp throttle response and driving experience overall?
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers)
Previous:
18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust)
16' F80 M3 (Ohlin R/T Coilovers)
13' Audi TTRS (APR Stage 1, MSS Springs)
09' C6 Z06
08' E90 M3
06' 335i (KW V2 Coilovers)
03' C5 Z06
TRZ06 is offline   Reply With Quote
Old 09-03-2019, 01:03 PM   #2
SJFGTO
Oh Oh it's Friday Night!
SJFGTO's Avatar
Drives: 2018 ZL1 1LE Nightfall Gray
You will pick up some HP. Drivability? Not significant enough to void your warranty and repay for further tuning if you add mods down the road.
2018 Camaro ZL1 1LE NFG; ARH 2” headers, catless mids, ARH full exhaust, Lingenfelter 18% lower pulley, ATI Harmonic Balancer, Roto-fab CAI, EE-catch can, TM ported TB, NX Lid, BMR strut tower brace. Aeroforce dual pod interceptor gauges. Tuned by Vengeance Racing!!! 644 HP @ 6250 rpm / 689 trq @ 3660 rpm
Four that wanna own me
Two that wanna stone me
One says she's a friend of mine...
SJFGTO is offline   Reply With Quote
Old 09-03-2019, 01:37 PM   #3
geaux_tigerss
geaux_tigerss's Avatar
Drives: 2019 GMC Sierra 1500 AT4
No way. Don't tune for less than headers/E85.
Buy a throttle controller or ported throttle body if you want to help throttle response.
Summit White
6" Lift, 37x13.50R24's
geaux_tigerss is offline   Reply With Quote
Old 09-09-2019, 06:00 PM   #4
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Drives: Red Hot A10 ZL1 Convertible
+1 this.
Gunkk is offline   Reply With Quote
Old 09-09-2019, 07:12 PM   #5
Vrodviddy
Drives: 2018 Camaro ss
I have to agree. It's best to do all the upgrades and mods that u plan on doing first. Just for $ sake alone. Any mod u add u going to need to retune to get the benefit out of it.anyone that's into adding hp will always look at hp gained vs cost. At very minimum if your considering tune on a dyno. E85.. intake and headers to make dropping 4 to 600 on a tune worth it. I did all my upgrades at once. Cam, headers, e85, rotofab, heads, dod delete, and springs. Still waiting for appointment at Vegence but they did my base tune and it was on point. Cause car very drivable even with just base tune. Highly recommend the one in cumming ga.
Vrodviddy is offline   Reply With Quote
Old 09-09-2019, 07:24 PM   #6
cmitchell17
Drives: 17 2SS, 8L90, Cam, Heads, E85
I personally have not been able to improve drive ability at all with a ECM or TCM tuning. That's not to say someone who understands the GM torque based control strategy better than I do or someone with better tools with access to more parameters may be able to though.
I have also not been able to confirm any more power through tuning, I did confirm about 25-29 rwhp peak from E75 and about 5 rwhp peak from NPP in track vs stealth.
The biggest drive ability problems being the unnecessarily hard low throttle shifting, overly sensitive and jerky low speed stop and go driving, and the extremely sensitive 50-75% throttle range. I have also tried using the CTS-V parameters, nothing seems to help or even make a difference when changing any of the parameters. Its hard to do unless you have your own personal proving grounds and engine dyno and multi million dollar lab equipment to confirm results, without that its just really good guesses and subjective trial and error.
cmitchell17 is offline   Reply With Quote
Old 09-22-2019, 02:40 PM   #7
My First Camaro!
My First Camaro!'s Avatar
Drives: '18 5.7 RAM 1500 18' 1SS
Power? Not really. After JRE tuned my car it ran better. Just better. I think its worth it. YMMV
JRE Tune
My First Camaro! is offline   Reply With Quote
Old 09-22-2019, 04:11 PM   #8
s346k
s346k's Avatar
Drives: like an old lady
tune only, otherwise stock..? i’d leave it be.
e85 and tune on a stock car? certainly.
2016+ camaro: everyone’s first car
s346k is offline   Reply With Quote
Old 09-22-2019, 09:12 PM   #9
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Far as ECM, 93 tune is worth 8-10whp tops. E85 flex fuel tune is worth 25-30whp
Far as TCM, not much to do on a manual. On a A8 3-4 tenths can be gained from a good TCM tune. Driveability can be much improved on over stock as well.
Moral of the story. Stock M6 SS on 93 octane...not worth tuning unless you do flex fuel.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP
Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA
KingLT1 is offline   Reply With Quote
Old 09-24-2019, 09:52 AM   #10
JDP Motorsports
JDP Motorsports's Avatar
Drives: 2011 Camaro SS/ 2016 Camaro SS
As mentioned in the other replies, there isn't much power or drive-ability to be had with a stock car. It just wouldn't be cost effective, unless you plan on installing headers/exhaust or a flex fuel setup.
Kind Regards,
Stephen
JDP Motorsports is offline   Reply With Quote
Old 09-25-2019, 12:08 AM   #11
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
E85 is worth the tune. but with a manual there is no other reason to tune until you do headers or E85. both really wake the car up.
JCunningham is offline   Reply With Quote
Old 09-25-2019, 07:28 AM   #12
GuywithL86
Drives: Black
I have my l86 truck stock but tuned. There is a ton of torque management with the truck, the shifts are lazy, the throttle is slow. My 0-60 went from 5.8 to 5.0 with just a tune.
The camaro does not suffer from same issues. I barely felt any torque managment, shifts were perfect. It was almost difficult to believe it was the exact same drivetrain.
I definitely would not tune a stock car.
GuywithL86 is offline   Reply With Quote
Old 09-25-2019, 08:46 AM   #13
KingLT1
KingLT1's Avatar
My trans tune makes a stock Camaro feel like a turd. Either way OP has a manual so Automatic talk is moot.
2016 NFG 1SS A8
Old 09-25-2019, 10:28 PM   #14
JCunningham
Drives: 2017 2SS M6
i have a 17 6.2l max trailering. getting the TCM back from HP tomorrow. good to hear it makes a big difference.
