09-29-2021, 02:18 PM | #1 |
Drives: 2021 chevy camaro LT1 Join Date: Aug 2021
Does anybody know is it OK to change chromoly pushrods with fully stock internals ?
So I got the Texas speed chromoly pushrods 7.850 - 3/8 Diameter. I was wondering if I can change them but I got the stock pistons and everything is stock for internal parts I was just going to add the blower and they said it's good to run with chromoly pushrods hold better on higher rpm but I see that people changer the pushrods when they do cams pistons and etc...
Any suggestions? Thank you |
10-01-2021, 08:33 AM | #2 |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
Anything that increases the force on the pushrods is a suggestion (or requirement) for stiffer pushrods.
The issue is about how fast the lifter-pushrod-pushrod rocker socket group is being accelerated during the valve opening event, against however much resistance is coming from the valve spring rates/settings. Stiff valve springs, cams with quick valve opening rates, and higher revs (which obviously must be opening the valves faster) all increase pushrod load. It's a stiffness thing, because under compressive loading, slender columns (pushrods fall into this structural category) will fail in buckling. But even before that happens catastrophically, they'll actually bend "out of straight" and potentially resonate at some frequency. Neither of which is good here. Norm
'08 GT coupe 5M (the occasional track toy)
'19 WRX 6M (the family sedan . . . seriously) |
10-01-2021, 02:09 PM | #3 | |
Thank you so much |
11-28-2021, 07:18 AM | #4 |
Drives: 2018 Camaro SS 1LE Join Date: Jun 2020
That's a common modification for cammed cars. If Texas Speed recommends it then you should probably follow their direction. There are weak links in any system and it could be by design. By swapping out pushrods to ones that are much stronger just means something else may give before they do now. I've been running chromoly pushrods in my 2002 Camaro for 80,000 miles, nothing has yet to break.
2002 Camaro SS | 2003 Corvette Z06 | 2008 Corvette| 2016 Corvette Z06 C7.R | 2018 Camaro SS 1LE
11-28-2021, 09:42 AM | #5 |
Drives: 2016 1SS NFG A8 Join Date: Aug 2017
LT stock push rods are already 3/8 diameter on these engines and fairly strong...quite a bit stronger then stock 5/16 pushrods in LS engines. It's a waste of money imo on a stock valve train engine. I have been running a supercharger for over 3yrs on a totally stock LT1 with no issues. Imo it would make more sense to move up to a slightly better valve spring if anything but again I haven't had any issues spinning 6700rpm @ 11psi of boost on stock parts.
2016 NFG 1SS A8
Options-2SS Leather/NPP Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA |
11-28-2021, 10:34 AM | #6 | |
Drives: 2017 Camaro 2SS A8 Join Date: Aug 2018
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors, LPE BB HPFP, 15” conversion 1059 WHP/944 WTQ, 9.48@150
11-28-2021, 11:44 AM | #7 |
Drives: like an old lady Join Date: Jun 2012
what was tsp's reason for changing pushrods? as stated already, they certainly are not the weak link in a stock internal engine.
2016+ camaro: everyone’s first car
Tags |
chromolly, internal build, internals, performance |
