Old 11-09-2023, 02:53 AM   #1
MakeShift1LE
Drives: '12 2SS 6MT
Weird sound <1000 rpm while coming off clutch
I've hearing this chirping-like sound when clutching out of any gear at low rpms. Sounds like something is loose but I'm not sure what it could be. I haven't been under the car to check yet but do you guys have any leads? Link to the video containing the sound.
https://www.youtube.com/shorts/6aNTZ2r_QSY
MakeShift1LE is offline   Reply With Quote
Old 11-09-2023, 05:00 PM   #2
RupertPupkin
Drives: 2014 Camaro SS 1Le
Brakes maybe? Just drive faster.
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads
FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch
730whp: 630Trq
RupertPupkin is offline   Reply With Quote
Old 11-09-2023, 05:49 PM   #3
SlowLS1
SlowLS1's Avatar
Is it only clutch in, or also clutch out?
SlowLS1 is offline   Reply With Quote
Old 11-10-2023, 11:44 PM   #4
MakeShift1LE
Drives: '12 2SS 6MT
Only when I'm letting off the clutch.
Old 11-11-2023, 03:05 PM   #5
bsn
Drives: 2013 ZL1
Sounds like throw out bearing, if the clutch pedal feels normal I wouldn't sweat it.
bsn is offline   Reply With Quote
Old 11-12-2023, 07:48 AM   #6
fz4k98
Drives: 2013 1ss
Does it do it in neutral when letting clutch out?
fz4k98 is offline   Reply With Quote
Old 11-12-2023, 02:18 PM   #7
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
My clutch kinda does that and my last too did it. Is it stock? When I beat on it it disappears. Metallic sound. Slave clearance maybe, I am not sure. Drives good and takes a beating I keep going.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE
Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me.
WHAMMO is offline   Reply With Quote
Old 11-13-2023, 02:20 AM   #8
MakeShift1LE
Drives: '12 2SS 6MT
Nope. Only when in gear.
Old 11-13-2023, 02:22 AM   #9
MakeShift1LE
Drives: '12 2SS 6MT
My car also drives perfectly fine despite the sound haha. I bought this as my first manual car back in 2020 and still don't really know if the clutch is stock or not. It's pretty heavy especially compared to the Japanese cars I've driven before that were all stock.
Old 11-13-2023, 07:38 AM   #10
fz4k98
Drives: 2013 1ss
If it does not happen in neutral the noise is most likely in the drivetrain, not the clutch system. The slave is under compression all the time and when the pedal is pushed it extends to release the clutch. It still could be clutch because it is not under load in neutral but you can check this by holding brake while slipping the clutch to see if it happens.
I would next try applying the emergency brake with light drag and see if noise is there.
Next apply emergency brake hard and slip clutch to load drivetrain to see if noise is there without moving the car. Alternate between 1st and reverse for maximum drivetrain play.
Next I would jack up car and by hand rotate the tires to see if noise is there.
These will help determine where in the drivetrain the issue is.
Old 11-18-2023, 04:52 PM   #11
MakeShift1LE
Drives: '12 2SS 6MT
Thank you for the tips and advice. I will definitely be trying this out.
