11-19-2010, 09:25 PM | #1 |
NEMESIS (NEMI-"SS")
Drives: 2011 2SS-LS3, BLACK W/CYBER STRIPES Join Date: Nov 2010
Widening the factory Wheels to 10.5?
After reading all the great threads, I'm going to stay with my Factory 20's, moving to a lowering kit of 1.4 front and 1.0 back with a 315 on the rear. I am thinking of moving the rear wheels to the front, then have the fronts widened to 10.5, (I do not want to run any adaptors) Wouldn't I be able to run a 315 in the back with a 10.5 R wheel? Does anyone know what the offset should be?... or better yet, anyone know a shop in the San Diego area that could do the work and is familiar with the offsets and fitment?? I've looked at some beautiful 22" set ups on the blogs and websites..... but I always come away thinking show car, Not HotRod. It must be the Oldtimer in me... but I think a good amount of rubber between the wheel and the road is a good thing. Hence the desire to stay with 20's, lower the car and put fat tires (to the wells) on it... any guidance is appreciated.
11-19-2010, 09:31 PM | #2 |
Drives: 2010 rs ss Join Date: Jan 2010
the 315's will fix just find. i hope you find someone in southern calif . i'll go there two. i would like to be able to walk into a shop and get this done.
11-20-2010, 12:23 AM | #3 |
Moderator.ca
moved to the wheel & tire section
__________________ Originally Posted by FbodFather My sister's dentist's brother's cousin's housekeeper's dog-breeder's nephew sells coffee filters to the company that provides coffee to General Motors...... ........and HE WOULD KNOW!!!!__________________ Camaro Fest sub-forum |
11-20-2010, 12:38 AM | #4 |
Drives: 2010 SS Camaro Join Date: Sep 2009
Was thinking about doing the same and bought another set of rears. I found a gentleman who can widen.... Vaughn Machine in Monrovia.
On a side note I wonder if the 245 will fit on the 20x9 until I find the money to have my new rims widened? Good Luck. |
11-20-2010, 06:35 AM | #5 |
NEMESIS (NEMI-"SS")
Thanks Hairzee.... Vaughn Machine was just the info I was looking for!
11-20-2010, 07:23 AM | #6 |
Drives: 2010 2SS/RS ; 1970 Firebird Formula Join Date: Jan 2010
I want to do the same with my rears. No spacers. Can it be done? By who?
11-20-2010, 11:00 AM | #7 |
Drives: 2010 Camaro 2SS/RS Join Date: Sep 2009
It seems every day someone asks about the widened wheels fitting so they should make it a sticky.
I have had two sets widened one was 10.75" and the other was 11". The later did require and adapter so it would not rub on the inside plastic liner. Take a look at the following threads. It explains it all. If you still have questions PM me or call me at (951) 571-352. I am on the west coast so it is still very early here. http://www.camaro5.com/forums/showthread.php?t=112448 http://www.camaro5.com/forums/showth...widened+wheels Jimmy BTW, I have a set of stock fronts I am selling that can be widened but they would need adapters. I have mad a couple widened already. Vaughn does a great job. If you widen the front wheels you must use an adapter. If you widen the rear wheel to 10.75" and use a 305 tire you are good. If you widen to 10.75" and use a 315 you may have to use a 1/4" spacer. When running the 315 at the track with low air pressure(15 psi) we saw a little rubbing on the inner plastic on one side(think it was the passenger side). If you widen to 11" you will need a spacer for 305 or 315 tires.
2005 Dodge Ram 2500 RCSB Thunder Road Hemi Sport w/STS Turbo
2004 Dodge Ram SRT-10 - Silver - Stock 2003 Chevy 1500 RCSB Stepside 400SS - 408 in now awaiting Turbo |
11-20-2010, 12:08 PM | #8 | |
Drives: 2010 2SS/RS Join Date: May 2010
LME built LSX427 w/t all Callies internals| AGP 65/65 TT | Holley Sniper Intake | Brodix BR3/LME custom ported | LME custom cam | Pro EFI 112 ECU | ID-1700x | NGK BR7EF | AGP's-Fore Triple Fuel pump | Monster LT1-S Triple | ZL1 3.23 diff, CF driveshaft, ZL1 axles | Hurst Line Lock | MGW Retro Short Throw | Pfadt solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Ground Control camber/caster plates | Accelerated Racing Solutions tuned| God is too good! I don't deserve it, but I sure will accept it!!! |
11-20-2010, 12:30 PM | #9 |
Because we are using the 10.75" rear wheels we do not need the spacer. But doing a little "search" I found that the H&R adapter is what others who have widened the fronts are using.
The 11" rears I sent my cousin do need a spacer but he is not in the US so I don't know where or what kind of spacer he used. Tell Vaughn the guy with the "pumpkin" or Halloween" wheels sent you, lol. He named them that because they are painted IOM and Black, lol.
11-20-2010, 03:40 PM | #10 | |
2nd..BUT then if I rotate the back rear rims to the front(to utilize the 275's in front) and then widen the front rims to take 315's THEN I'll need a spacer......CORRECT????
11-20-2010, 04:18 PM | #11 | |
1. Yes 2. No 3. Yes 4. Yes So if you are going to run the 10.75" wheel on the NT-05R in 315 and plan on lowering the tire pressure for the track I would: 1. Use a 1/4 spacer(the one that does not have lugs on it) just to be 100% sure it will not rub. That is what we ended up doing just to be sure it will not rub. Or 2. Get the wheel in 10.50" instead on the NT-05R in 315 with no spacers and you will have more clearance for dropping the car. If you are going to run the Nitto NT-555R then you can use the 10.75" with no spacers and no rubbing whatsoever. I can't say the same for other manufacturer's tires as I have not used any other brand; only Nitto NT-555R in 305 and NT-05R in 315.
11-20-2010, 04:27 PM | #12 | |
AND thanks for taking the time to answer all the noob questions brother!
11-20-2010, 04:39 PM | #13 | |
Also, widening the wheels add to the inside(backspace) so it does not make the wheel stick out any farther then stock. But to run a 11" wheel you have to use a spacer so it doesn't rub on the inside which then sticks the wheel out as much as the thickness of the spacer you use. I think up to 1/2" spacer will still not stick out past the fender but it depends on the tires used and the amount you widen the wheel. What are your plans? Are you looking for some nice 315's for the street or are you looking to get some drag radials for the track? The reason I ask is others have posted that the 315 from Nitto is not as wide as other brands. I don't know if that is true or not as I have never measured though.
11-20-2010, 04:50 PM | #14 | |
Are you running your SS? What times and traps?
Similar Threads | ||||
18" Factory OEM Wheels Rims for Sale | K-Dub | Wheels and Tires Talk Sponsored by The Tire Rack | 2 | 11-24-2010 10:03 AM |
Wanted to buy: 20" OEM Factory Chromed wheels | prostock69 | Wheels / Tires | 13 | 07-28-2010 12:07 PM |
SLP 2010 Camaro ZL575 supercharged -- unique aero parts & "SS" on grill | nUcLeArEnVoY | Camaro Photos | Spyshots | Video | Media Gallery | 129 | 04-22-2010 02:59 PM |
Why use premium gas? | avro206 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 81 | 01-11-2010 02:38 PM |
Factory Chrome Wheels Available - 20x8 & 20x9 Group Buy | talwell | Wheels / Tires | 1 | 12-18-2009 02:40 PM |
