Old 08-10-2013, 05:26 PM   #1
Meister
Meister's Avatar
Drives: 2016 Corvette Stingray Z51
Convertible rear seat removal
Would anyone with a vert know how to remove the rear seat? I can get the seat bottom out no problem but I can't seem to find a way to remove the seat back. Thanks for any help.
Meister is offline   Reply With Quote
Old 08-10-2013, 09:03 PM   #2
Mykeb
Happiness is.....
Mykeb's Avatar
Drives: '13 2LT Convertible, '56 F100
The service manual says (after you remove the bottom seat cushion):
1. Using a flat bladed tool, release the seat back retainers through the access holes located between the seat back cushion and the rear end trim finish upper panel.
2. Fold the seat back cushion down and line up the flats on the hinge pins with the slots on the hinges.
3. Pull the seat back cushion upward to remove it from the vehicle.
It appears there are two retainers and they are located at the top rear of the seat back cushion, each one is centered on the left or right seat. Hope that makes sense.
I was young and had money once. Bought an old truck and that was that.
Mykeb is offline   Reply With Quote
Old 08-10-2013, 09:09 PM   #3
impaidbyu
Drives: 2013 rs/ss Convertible
Like was said above the two retainers are about 6-8" in on the top of the seat, I used my fingers to pull the seat forward and stuck a flat head screwdriver in to pop the retainers. There is a good thread with pics and a vid for the removal if you search "sports bar".
Good luck
impaidbyu is offline   Reply With Quote
Old 08-10-2013, 09:10 PM   #4
impaidbyu
Here is a youtube vid also might help
Old 08-10-2013, 09:17 PM   #5
Meister
Meister's Avatar
Thanks for the help. I posted this in another section and received the info there too. Got it taken care of. Simple once you know the secret.
convertible, rear seat removal
