View Poll Results: which would you use?
91 7 13.21%
93 45 84.91%
NON Ethanol 1 1.89%
Voters: 53. You may not vote on this poll
Old 06-28-2011, 03:44 PM   #1
rowerybo
Drives: explorer
gas, what would you use?
I've seen the threads about 87 in the SS cars and I'm looking a little higher. I'm fortunate enough to live in an area where there are stations that offer 91, 93, and non E gas (not sure of the octane).
If you had those options, which would you run?
rowerybo is offline   Reply With Quote
Old 06-28-2011, 03:46 PM   #2
woodstock
woodstock's Avatar
Drives: 2012 Corvette Grand Sport
Premium,it keeps the sensor clean in your tank. As well as runs better and stronger
woodstock is offline   Reply With Quote
Old 06-28-2011, 03:46 PM   #3
Dznts
Anabolic Connoisseur
Dznts's Avatar
premium only.. !
Old 06-28-2011, 04:10 PM   #4
HookemHorns
HookemHorns's Avatar
Drives: 2023 Camaro ZL1 Red Hot Convertible
Premium only regardless of price!
HookemHorns is offline   Reply With Quote
Old 06-28-2011, 04:17 PM   #5
Fuel Fire Desire
Fuel Fire Desire's Avatar
Drives: 2011 M6 LS
Premium will keep the fuel schedule leaner, giving you more power. Also, it smells better.
Fuel Fire Desire is offline   Reply With Quote
Old 06-28-2011, 04:29 PM   #6
RubyCamaro
Jan
RubyCamaro's Avatar
93 octaine only. It makes te car more responsive & have more power. Also use only "top tier" gasoline (approved by GM). As best I recall is has to do with having enough detergent to keep the fuel systems clean & working properly. Around here that is Shell mostly. There is a thread on C5 somewhere about using top tier fuel but I am at work & don't have time to search it.
Old 06-28-2011, 04:36 PM   #7
VTXrider
VTXrider's Avatar
Drives: 2010 RY 2SS/RS
I am not participating in the poll as there is not enough information for me.
According to any auto manufacturer I have ever seen, anything 91 or higher is considered premium so I don't understand those answering premium. I would lean strongly toward 93 but I would have to see the price difference between that and 91. 5 cents as it is here for me, I buy 93.
I would buy non-ethanol, provided it is at least 91 if it was not more than 3-4% more than the others. One note here is that for cars older than 2007-2008 I would pay up for non-ethanol because their fuel systems are not made for ethanol exposure and will deteriorate over time even from E10.
No answers here, but something to think about. Hope this helps
edit: This assumes you have a stock tune, if you are tuned for 93 then you should use 93.
VTXrider is offline   Reply With Quote
Old 06-28-2011, 04:40 PM   #8
CamaroFemme
CamaroFemme's Avatar
Drives: 2010 Black Camaro 2SS/RS
The SS needs at least 91 or it goes to the lower performance table and you have to do a fuse pull to get it to return to the higher one (at least on the '10s.)
Wikipedia (I know, right?) states that there is no benefit for running higher than a car's stated octane minimum if you aren't tuned for it. I do anyway.
But your poll is flawed as 91 or 93 can also be non-ethanol. (And Ethanol does cause a car to burn gas quicker.)
My boyfriend don't mind it.
CamaroFemme is offline   Reply With Quote
Old 06-28-2011, 05:19 PM   #9
Outlaw77
Outlaw77's Avatar
Drives: 2018 Charger SRT 392 F8 Green
I use 94 octane with no ethanol.
Outlaw77 is offline   Reply With Quote
Old 06-28-2011, 07:05 PM   #10
CaniacFan
CaniacFan's Avatar
Drives: '10 SS CGM #75,288, '14 Stingray
Nothing but 93 ever for my baby.. For 10 cents more a gallon than 91 ($1.50 p/fillup) it's a No-brainer.l
CaniacFan is offline   Reply With Quote
Old 06-28-2011, 07:08 PM   #11
KnightRiderSS
Voodoo Medicine Man
KnightRiderSS's Avatar
Drives: Black 2SS with RS package
Wow...I guess I am the only Camaro owner that uses regular unleaded?
I haven't had any knocking issues at all....
Blasphemy?
KnightRiderSS is offline   Reply With Quote
Old 06-28-2011, 07:11 PM   #12
CamaroFemme
Blasphemy?
I don't think it will hurt it - I believe the law states that all cars have to be able to run on 87. But do this for us - drive it to near-empty, fill it with at least 91, do the fuse pull, drive it - and get back to us. You WILL see a difference.
http://www.camaro5.com/forums/showthread.php?t=38964
Old 06-28-2011, 07:13 PM   #13
KnightRiderSS
Voodoo Medicine Man
I will give that a try....
I've never used anything except unleaded....it still will roast the tires....
My next fill up I will give it a try and see how it feels....
Old 06-28-2011, 07:15 PM   #14
Banshee
Institutionally Insane
Banshee's Avatar
Drives: 2013 IOM 2SS/RS 1LE
The poll is flawed.
You can get 91 or 93 with or without ethanol.
As well, at higher altitudes, the highest is typically 91 with 93 octane at lower altitude. Typical grades lower altitude 87/89/93 (with 86 at Sunoco) or 86/87/91.
To answer...if you are concerned, 93 non ethanol or 91 non ethanol at altitude.
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspension, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas. What do you say, is it the new Bluesmobile or what?
Banshee is offline   Reply With Quote
PQ don't need no stinking onstar... Real men walk to get Gas..... GTAHVIT Off-topic Discussions 215 12-19-2018 06:21 AM
Mixing Gas to get 93 Octane FarmallsForever Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 29 06-03-2013 06:19 PM
Acronyms? KEEP RT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 20 03-11-2011 08:57 PM
Bad gas! Camaro sputtered & died gzartman Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 8 09-07-2010 05:45 PM
Fuel pump or bad tank of gas? Boomer Sooner 4th Generation Camaros 25 01-02-2009 06:34 PM
