12-08-2016, 03:23 PM | #1 |
turbo only makes 4psi
I have a Huron Speed single turbo (7475) after having it installed and put on the dyno it would only build about 4psi while trouble shooting we added a manual boost controller and it would still only make about 4psi. I purchased a 10lb spring and same results, My installer has checked and rechecked for leaks the BOV is running the stiffest spring that it came with... Any suggestions from the turbo gurus in here
12-08-2016, 03:33 PM | #2 |
Drives: All things Turbocharged Join Date: Dec 2010
Almost for sure the wastegate or a boost leak.
Is the stock crack case hose just blowing all the pressure from the manifold into the valve cover? |
12-08-2016, 03:34 PM | #3 |
Drives: 14 1le turbo Join Date: Oct 2015
Do you have a cheap wg and bov?
2014 1LE 2SS/RS
Huron Speed turbo kit |
12-08-2016, 03:42 PM | #4 |
It has the wastegate and BOV from Huron I believe its all turboSmart Stuff except we put a 10LB spring in the wastegate
12-08-2016, 03:53 PM | #5 |
My tuner said no because the catch can (mighty Mouse)
12-08-2016, 04:22 PM | #6 |
Drives: 2013 Camaro SS Turbo Join Date: Apr 2014
Put some pics of the engine, vacuum lines, wastegate, ect
12-08-2016, 05:04 PM | #7 |
Too much is never enough!
Do you have a check valve installed on your catch can?
12-08-2016, 05:38 PM | #8 |
This Im not sure about It was spec'd by Mighty Mouse for my turbo kit and HP Goals... a gen4 pcv can system...
Yes as per Mighty mouse the can is boost checked Last edited by Da2ss; 12-08-2016 at 08:02 PM. |
12-08-2016, 07:58 PM | #9 |
Do you install the fire ring on the wastegate?
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/ |
12-08-2016, 08:05 PM | #10 |
12-08-2016, 08:12 PM | #11 |
Post some pics man need to verify how everything is hooked up
12-08-2016, 08:15 PM | #12 |
Ill try to run by there tomorrow and grab a few pics I appreciate the suggestions so far
Thank you |
12-08-2016, 09:17 PM | #13 |
I guess step 1 is how are you reading 4psi? Are you sure that is accurate?
Nick
Corvette Z06 -1200ish rwhp |
12-08-2016, 09:33 PM | #14 |
Im using AEM 30-4406-30-35 psi boost gauge
