Old 10-02-2010, 07:24 PM   #1
raqball
raqball's Avatar
Drives: 2010 Camaro
CoStar / BlueStar installed and working!
I received my CoStar / BlueStar module today and installed it... The install took all of 20 minutes... It paired right up with my HTC EVO and works right out of the box...
It is truly plug and play and the hardest part of the install was removing the glovebox...
This is now a great bluetooth option for those of us who do not have the factory bluetooth.. You do however loose all OnStar functions... I personally can care less about OnStar and IMHO it's way overpriced once the free trial is up...
The CoStar / BlueStar module is $279 shipped and can be ordered here.
http://www.costartech.com/pb/products/bluestar.html
Install process
1. Remove the bungie style cord from the right side of the glovebox
2. Squeeze / push the glovebox ends in so the tabs clear the molding
3. Remove 5 screws that hold the upper portion of glovebox in place and pull downward to remove
4. Unplug and remove the OnStar box
5. Plug BlueStar in and reinstall the glovebox
6. Pair your phone and enjoy
I was going to add photos but the install is so simple, they are really not needed...
raqball is offline   Reply With Quote
Old 10-02-2010, 08:01 PM   #2
EDGE_
EDGE_'s Avatar
Drives: 2010 1SS/RS SIM L99
Thanks Raqball. As soon as my year is up this will be the route I am taking.
EDGE_ is offline   Reply With Quote
Old 10-02-2010, 08:06 PM   #3
raqball
raqball's Avatar
Drives: 2010 Camaro
No problem... I am thrilled that they worked out the bugs from the prior attempt to install it...
It now plugs right in and works right out of the box... Voice dialing from my EVO works, the sound through the car speakers is clear, and everyone said I sounded clear on their end during several test calls...
Old 10-03-2010, 02:54 AM   #4
mike.nite
mike.nite's Avatar
Drives: 2011 2SS L99, 2010 LT RS
congrats on the instal!
- Can you also make nametags?
- Does it show the bluetooth activities on the radio display?
(i.e. incomming call, dialing, name of the phone, ...)
- can you use steering wheel controls
Just trying to figure out if you have the same features as with the factory onstar bluetooth.
mike.nite is offline   Reply With Quote
Old 10-03-2010, 05:09 AM   #5
raqball
raqball's Avatar
Drives: 2010 Camaro
I have not really played with it a lot since I just got it installed yesterday...
--No nametags that I am aware of
--Does not show BT activities on the radio (other than bluestar connected)
--Not sure about steering wheel controls (I don't have them) but I think it says they do work on their website..
I will test these out today and report back later...
Old 10-04-2010, 12:07 PM   #6
c_LoW29
Drives: 2011 2SS/RS, 2010 Mustang GT
Music through the bluetooth?????
c_LoW29 is offline   Reply With Quote
Old 10-04-2010, 01:21 PM   #7
raqball
raqball's Avatar
Drives: 2010 Camaro
After a few days of playing with it here are some answers again..
-- No nametags
-- Does not show activity on radio.. It only displays BlueStar connected
-- The website says steering wheel controls work but I do not have them so I can't say for sure...
No to music.... BT phone ONLY functions...
The sound quality is great... This box simply replaces the OnStar calling functions and not the BT factory functions... IE... If you have OnStar and use that calling function where you use OnStar purchased minutes... This allows you to use your cell phone minutes via the OnStar mic and speakers...
It is not a replacement for the factory BT add on..
Did that make any sense?
The best I can tell the Camaro has 2 separate BT abilities... One is OnStar where you purchase and use OnStar minutes the other is the factory installed BT....
Old 10-05-2010, 03:17 PM   #8
mike.nite
mike.nite's Avatar
Thanks for the infos Raqball.
This is definately a interesting alternative for those who can't get their hands on a used BT/Onstar module!
Old 10-05-2010, 05:56 PM   #9
sherifdude
MEAN MACHINE
Drives: 2010 CHEVY CAMARO 1SS/RS
looking to trade my onstar with no bluetooth for one with onstar with bluetooth
sherifdude is offline   Reply With Quote
Old 11-17-2010, 08:45 AM   #10
twnorman
twnorman's Avatar
Drives: 2010 Camaro 1SS - RS package
BTW - I emailed them last week asking if the music streaming worked for this and Chris said he should have it working by end of year and it would be a USB upgrade.
twnorman is offline   Reply With Quote
Old 12-24-2010, 12:26 PM   #11
twnorman
twnorman's Avatar
costar bluetooth install
I just installed mine today. I had to adjust it through the software provided so that my voice on the other line didn't sound scratchy, tinny. However, I am waiting to hear back on why it won't automatically pair the next time I get into the car.
Question for others that have installed this. Did you completely remove your onstar module? I thought I read somewhere that you need to leave it in (there are two other connections that are still wired to something). If you left the onstar module in, how did you position the costar module so that you could get the glovebox reassembled?
Thanks,
Tom
Old 01-13-2011, 02:40 AM   #12
buddylok
buddylok's Avatar
Drives: -
I will probably order a BlueStar box before the end of the month.
buddylok is offline   Reply With Quote
Old 01-13-2011, 09:04 AM   #13
Iwantone2
Voice Of The Voiceless
Iwantone2's Avatar
Drives: CGM 1SS RS
Thanks,
Tom
I know this is a late reply, but yes, you do need to completely remove the OnStar box.
Old 03-07-2011, 04:03 PM   #14
KowalskiCamaro
KowalskiCamaro's Avatar
Drives: 2010 Red Jewel 1SS & 2011 Durango
Can't find the Costartech site...
Help! I need bluetooth and this seems like the best option for me. Why can't I find it? The link above does not work.
KowalskiCamaro is offline   Reply With Quote
Installed Modified AAC LED side markers/turn signals GearHeadPeter Cosmetics and Lighting Modification Discussions 15 01-20-2013 07:09 PM
L99 Kenne Bell 2.8L Installed + Pics SonnyakaPig Forced Induction - V8 38 05-17-2010 03:20 PM
Front driver side speaker and tweeter not working Shown_nuff Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 1 05-01-2010 08:07 PM
Just Installed My Hurst Short Throw Shifter Blueclyde V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 3 02-17-2010 07:47 PM
Dealer installed pdim not working help! Yellow1lt Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 2 01-15-2010 09:17 PM
