Old 04-12-2012, 02:40 AM   #3151
carbon8
Drives: 2010 Camaro SS,2008 Hayabusa
Looking good
Fastest camaro in OKC
carbon8 is offline   Reply With Quote
Old 04-12-2012, 07:39 AM   #3152
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
Man, that is pretty impressive.... but it's not available yet according to their web site..
We went with the Aeromotive Stealth 1000 (800 lb/hr)set up.. including the controller, the regulator and new fuel rails... -8 supply and -6 return. We'll start with -8 feed and go to a -10 if needed...
As before, the regulator has a boost reference port, so that as we get into boost, the regulator will increase lb/lb as the boost increases to keep a relatively neutral feed reference...
ie: at no boost, the regulator is feeding 60 psi... at 5 lbs of boost, the regulator ramps up to 65 psi, at 18 lbs of boost, the regulator will ramp the pressure up to 78 psi... What this equates to is nice steady state fuel feed across the board...
what about 13 psi?
I piss excellence
and fart awesomeness
Old 04-12-2012, 08:07 AM   #3153
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
what about 13 psi?
G.
You're killing me bro... LMAO...Shall I do a chart, or maybe a bell curve... 13 is unlucky so we skip that boost number
Old 04-12-2012, 09:39 AM   #3154
Camaro21
Drives: SOLD - 2013 M6 ZL1
Looks like Brandi is coming along !!
Camaro21 is offline   Reply With Quote
Old 04-12-2012, 10:44 AM   #3155
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Slowly but surely... Baby steps right now, can't afford any mistakes....
Old 04-12-2012, 10:58 AM   #3156
Camaro21
I hear that !!
Old 04-12-2012, 11:04 AM   #3157
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
I hear that !!
Cutting my console out was painful... but it's done... Now when Corey gets off the dyno we'll stab the trans and go from there... I may be headed to Thrash Drive Shafts this afternoon... Drop mine off to have it adjusted and the front crossed over to a 1350 Yoke...
Old 04-12-2012, 11:12 AM   #3158
Camaro21
It's gonna be a BEAST when it's all done !!!
Old 04-12-2012, 07:50 PM   #3159
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Well today we got the fittings for cooling and sensors for various purposes moved over to the new transmission... I also did the preliminary cut out for the added length... I've got to trim a little more in the morning now that the trans is in the car... I was conservative with my first cut... Joe came by this afternoon and created all kinds of mayhem... J/K... Joe is going to be doing the repairs to the interior console...
Late this afternoon, we finally got to stab it in... It took a little doing but we got it and it looks great...
The black plastic piece is put there to help me gauge how much of it has to be cut... I've already trimmed some of it...
In these pics, you can see the adapter plate that the throwout bearing and slave cylinder rest against...
There are also various pics of the trans prior to stabbing it in...
Here's a few pics of the trans as it sits in the car... Bare in mind we haven't modified the cross member yet, so it is sitting on a screw jack... I have to trim the shifter hole about another three quarters of an inch prior to putting it to it's final position...
In the am, in addition to fitting it to its final position, I will be taking measurements and taking my drive shaft to Thrash is san Antonio to have the drive shaft length altered and the proper yoke installed on it...
Here is what happened today on Brandi
Old 04-12-2012, 08:18 PM   #3160
CamaroSpike23
Truth Enforcer
G.
do you happen to have a compressor map for your turbos? jw.
looks like you may need to fab up a new trans brace.
I piss excellence
Old 04-12-2012, 08:48 PM   #3161
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Not for the new ones... But I'll check tomorrow and see what I can get...
Yeah... The interesting part may be the drive shaft loop... We'll look at that some more tomorrow...it gets real crowded with the three inch exhaust pipes...
Old 04-12-2012, 09:17 PM   #3162
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Stupid question but there's not structural integrity lost by cutting is there?
Old 04-12-2012, 09:24 PM   #3163
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
No not at all...
All I cut was a small amount of sheet metal...
Old 04-12-2012, 09:37 PM   #3164
Orange Krate
Not just any car!
Orange Krate's Avatar
Drives: Orange Krate DOB - 11/22/2010
I would worry about the structural integrity of Robert's bunghole as he smashes down on the accelerator for the first time with that new setup! Especially if the horsepower happens to make it to the ground and the car hooks up! HA HA
Orange Krate is offline   Reply With Quote
225.8, camaro of the week, drive shaft specialists of tx, dss, erl, henderson performance tech, i am second, rockland standard gear, slayer billet quad carbon, texas mile, the circle, tracspec motorsports, twin turbos, w-bar's lord satchmo of lazy d
