Old 04-25-2014, 09:36 AM   #1
1 BADD 1LE
Black Widow
1 BADD 1LE's Avatar
Drives: 2014 Camaro 427SS
LSX 427 or LSX 454
Members,
I have sold my 2.9L Whipple Supercharger and am in the process of selling my LS3 Long Block to someone (pic attached). The team at Lethal Racing is preparing to start the second phase of my build after Camaro Fest next week. We will be going with a set-up that produces 1000rwhp (engine, supercharger, fuel system, Meth Injection) at 70-75% of the engine/blower capacity. I am hoping for around 1100-1200 RWHP, so we can tune it down to a conservative 1000rwhp for street use. I know that sounds insane, but my goal has always been to have a 1000rwhp street car! My question to the forum members is which engine would you go with, LSX 427 or LSX 454, and why. Once the build is complete, with the supporting drivetrain components upgraded, we will be tracking the car some, but it will remain my street car/show car toy...thanks and look forward to hearing from you guys!!!
100% Lethal Racing Built/Tuned/Maintained
*Black Widow Camaro 427SS*
1 BADD 1LE is offline   Reply With Quote
Old 04-25-2014, 09:41 AM   #2
62nalide
62nalide's Avatar
Drives: 2013 SS
IMHO I'd say 427
62nalide is offline   Reply With Quote
Old 04-25-2014, 09:43 AM   #3
gajagfan
gajagfan's Avatar
Drives: 2013 1SS 1LE Black - Std Exhaust
From the old carbureted days, its hard to beat cubic inches. Go big or go home! That my not apply to today's engines if there are better performance parts for the 427 than the 454. I am not sure what the differences are between the two to start with, so my comments may be of no value.
gajagfan is offline   Reply With Quote
Old 04-25-2014, 09:44 AM   #4
copper98
Camaro 5 Muscle
copper98's Avatar
Drives: 2012 CAMARO 2SS/RS
Nothing beats cubic inches - 454
Sent from my Nexus 5 using Tapatalk
Mods: Air Raid C.A.I., Custom Ported/Polished Throttle Body, Kooks 1 7/8 Headers, Dyno Tuned , LPE 3.91 Gears, BMR Differential Bushings, R/X Oil Catch Can, X-Pipe, Borla Exhaust, MGW Shifter, Hawk-HPS, SS brake lines, BMR front & rear sway bars, BMR rear sway bar end links, Pedders front radius rod bushings, Spohn front sway bar end links, BMR rack/pinion bushing, BMR Coils 1" drop, BMR Trailing Arm, BMR Toe Rods, Pedders Sub-Frame bushings, BMR Sub-frame Connectors, BMR Driveshaft Tunnel Braces, GM Strut tower brace, custom painted bowties
copper98 is offline   Reply With Quote
Old 04-25-2014, 10:20 AM   #5
62nalide
62nalide's Avatar
Drives: 2013 SS
Depends on what it's used for, Force Induction isn't the best thing to run on a 454 LSX.
Old 04-25-2014, 10:22 AM   #6
SemperGumby
I'll probably offend you
SemperGumby's Avatar
Drives: 2013 2SS/RS M6
454 > 427. Makes sense to me.
SemperGumby is offline   Reply With Quote
Old 04-25-2014, 10:26 AM   #7
Unreal
Drives: 2006 Z06
Only difference is the size of the piston, and thickness of the walls. 454 will actually be weaker. On a n/a build that isn't stressing the block the extra cubes can be nice, but for a 1000+rwhp build you are just making it weaker and the power adder will determine the power, not the size of the motor.
Nick
Corvette Z06 -1200ish rwhp
Old 04-25-2014, 10:27 AM   #8
62nalide
62nalide's Avatar
Drives: 2013 SS
Under boost not so much
Old 04-25-2014, 10:29 AM   #9
BplumCrazy-SS
BplumCrazy-SS's Avatar
Drives: 416 w/TH400
depends on what kind of boost you will be running but my vote would be 427 for reliability since its more of a street/show car........ its not hard to hit 1000+ on a 427
ERL 416 - 12.5 cr, TH400, Custom VVT Cam, PRC 255 heads, NW 102 TB, Aeromotive stealth fuel system, Fast 102 plumbed with a nitrous express direct port kit, BMR 15" conversion kit
BplumCrazy-SS is offline   Reply With Quote
Old 04-25-2014, 10:54 AM   #10
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
Drives: 2013 Camaro SS
Lol one day you're selling it, one day you're upgrading it, one day you're getting new wheels, the next day you're getting different wheels..
Now you're selling your engine and putting in a new one for a 1krwhp "street car"..
Going to be interesting to see if you're even remotely satisfied when you're done this time around...
Go with a 427.
2013 AGM Camaro 2SS/RS M6 | LSA Blower, 2.5" pulley, 10% lower, FIC1000's, Fore Innovations Twin Pump fuel system w/ Flex Fuel, CMS Custom Grind Cam, Kooks 1 7/8" headers w/ catless off-road pipes, NPP Exhaust, 3.91's, JLT ZL1 Intake, Prospeed Heat Exchanger | Pfadt Suspension, 1LE Sway Bars | DSS 1000hp axles |
Tuned by Ryne @ CMS E85: 734rwhp/636rwtq (mustang dyno)
Jeff_SS is offline   Reply With Quote
Old 04-25-2014, 01:57 PM   #11
Nightmare2012
come find out;)
Drives: stockish 2012 camaro ss
LSX427 IMO
Nightmare2012 is offline   Reply With Quote
Old 04-25-2014, 03:09 PM   #12
Rdphish73
Rdphish73's Avatar
Drives: 2012 Ashen Grey LS-3 RS/2SS Coupe
"Conservative 1000hp for street use" he says....
2012 AGM LS-3 RS/SS: Airaid CAI, Ceramic Coated Dynatech SuperMaxx LT Headers, High Flow Cats, Borla "S-Type" Cat-Back Exhaust, Ted Jannetty Tuned, LS-3 Cowl Badging, RS/SS Fender Badging. Custom Bow-Ties by Lupe
Rdphish73 is offline   Reply With Quote
Old 04-25-2014, 05:45 PM   #13
AG454
I am not "Fast & Furious"
AG454's Avatar
Drives: 2010 Camaro LSX454 1LE
I vote for the 454. It's a monster engine NA, I can't imagine it FI. GM says the block can handle 2000HP, but maybe the cylinder walls are too thin for high boost.
The day I take a bend too fast
Judgement that could be my last
I'll be wiped right off the slate
Don't wait up 'cause I'll be late, I'll be late
AG454 is offline   Reply With Quote
Old 04-25-2014, 09:25 PM   #14
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
Not only are the walls too thin for boost but a 454 will have a greater chance of detonation because of the shear piston size. A 4.00" stroke engine will be in theory more reliable than a 4.10+" stroke engine as well. There are 3 reasons he should do a 427 over a 454 and all of them deal with reliability with that much power and boost.
OP, you should look into a re sleeved ERL block as well if your budget will allow it. That way you can still have a 6 bolt block but it will be aluminum. Between the blower and LSX block its probably another 200+lbs on the nose of your car. http://www.erlperformance.com/gm-ls-...-block-sleeved
