02-15-2012, 11:54 PM | #1 |
Yellowbird
Drives: 2011 Camaro 2SS/RS/ L99 Join Date: Nov 2011
details and proof please [octane levels]
Why does ONLY pulling the fuse work? If I'm not mistaken when you pull a fuse that cuts the flow from the main power to the octane table, right? and in result "resets"? So why doesn't it reset if the main power is taken out? I'd like to hear from people that have an understanding of electricity if possible.
...also where can I find a original GM document that states the octane table isn't active and that it has to be manually reset by pulling fuses? Thanks in advance |
02-16-2012, 12:27 AM | #2 |
Drives: 2011 Camaro 2SS/RS Join Date: Dec 2010
I believe you'd achieve the same goal by pulling the main power, but then you would have to reset all your other settings, this way you isolate the fuses you need to reset the octane table.
02-16-2012, 12:31 AM | #3 |
Yellowbird
No argument there but the word on the forum is that only a fuse pull works and taking the battery out unfortunately doesn't work.
02-16-2012, 07:19 AM | #4 |
Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
Ask your dealer to look up bulletin PIP4728.
That came out back when the '10s were doing it. That bulletin is for the '10 L99, but many have found it to work on all 5th gens. The fuse vs battery disconnect thing may just be in how the memory is saved or reset. Different types of power downs may do different things. The bulletin specificly says to pull the fuses. Plus that saves you from having to reset the window indexing. |
02-16-2012, 09:01 AM | #5 | |
Drives: 2012 Camaro 2SS/RS Join Date: Jul 2010
I don't know the "magic" behind all this either, but here is what GM says:
02-16-2012, 09:16 AM | #6 |
SoCal Mayhem
Drives: 2010 Camaro 1SS/RS Join Date: Aug 2008
WOW this is really bugging you huh?
02-16-2012, 09:18 AM | #7 |
Caspers2SSRS
Drives: Summit White 2010 2SS/RS Camaro Join Date: Jul 2010
Thanks E.T ....that should pretty much wrap things up.
02-16-2012, 09:48 AM | #8 | |
The New Guy
Drives: 2010 2SS/RS IBM M6 Join Date: Sep 2009
But if you don't trust it that much it cool just don't pull the fuses, i would venture to say more than 90% of camaro owners wont ever pull the fuses. it is just for those that have the speed addiction
02-16-2012, 11:15 AM | #9 |
love. my. car.
Just wondering, if the bulletin is only for 2010 L99 Camaros, can you reasonably assume that the issue never existed for the LS3 and that the issue is resolved for 2011+ models? Why would GM create a TSB for only L99 if it could possibly affect the LS3?
Also if GM is aware of the issue, what would have stopped them from resolving the issue in the next model year or a mid-model-year software update?
02-16-2012, 11:55 AM | #10 | |
The New Guy
02-16-2012, 12:00 PM | #11 |
Switchin' n Twitchin'
Drives: 2011 Camaro Join Date: Nov 2010
Pulling the fuses lets capacitors drain, removing battery power still has power to the capacitors and therefore nothing is reset. As for the tables, that's in a binary setting that GM engineers know. I don't have spare parts sitting around to test as to why it works, but this is just a basic electronics knowledge from my experience as to why fuses are pulled and not disconnecting the battery.
~U.S. Navy Electronics technician for 11+ years and counting...
I am not childish, you're just being a poopy head!
02-16-2012, 12:07 PM | #12 | |
knows 2 facts about ducks
