04-30-2010, 04:52 PM | #1 |
SS #2431
Drives: 2001 Pewter Camaro SS Join Date: Jul 2009
Gauges/Overheating
Okay so I have a quick question. Recently i've noticed that my temp gauge keeps going all the way into the red. I would get it checked, except I'm not sure if it's anything really bad. my suspicions are because the gauge will go from about 180 to 260 in 2 seconds and as soon as i get above 2k RPMs it drops back to the middle. kinda stumped.
My dad seems to think i need a new waterpump or something along those lines. when I was changing my oil a week or so ago I noticed a small amount of green (antifreeze i think?) liquid, but it wasn't leaving a puddle or even dripping. it was just on there. Help would be appreciated! I'd rather have my dad help me replace whatever it is rather than pay to replace it. Thanks guys |
04-30-2010, 05:29 PM | #2 |
Drives: 2SS/RS Join Date: Sep 2008
Where was the liquid located?
Hate to ask the most logical question but is it topped off? When you have a chance drive the car for a few miles (5-10 don't need many) and look under the car at the water pump. On the bottom there is a little weep hole. If there a little near or on the weep hole (it might nott be enough to drip so you might have to rub it with your finger or a white paper towel) then you need a new water pump. When I replaced mine I think it was $180 for the pump and took a couple hours to do. It also could mean you need a new thermostat or both. |
04-30-2010, 05:31 PM | #3 | |
I am the internets.
04-30-2010, 05:33 PM | #4 |
BAMF SS
sounds like you have an air pocket. bleed the coolant system... add coolant accordingly.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
04-30-2010, 05:35 PM | #5 |
Drives: 2016 Mazda6, 2011 Mustang 5.0 Join Date: Mar 2010
Overheating is always a big deal. When you say it takes two seconds, do you mean that literally, or is that just supposed to mean it rises and then falls quickly. If it is literally two seconds, it might be the gauge, temp sensor, or an air bubble in the system.
If it is not the gauge and the coolant temperature is actually increasing and decreasing like that, it could either be a weak water pump or a plugged radiator. Either way, coolant isn't getting through the radiator at idle, but when the RPMs increase, and the water pump is turning faster, it is getting coolant through. I had a friend have this happen to an old truck once.
2022 1SS 1LE (Arrived 4/29/22)
"The car is the closest thing we will ever create to something that is alive." . 2022 1SS 1LE (Coming Soon) |
04-30-2010, 06:21 PM | #6 |
Drives: GM Stuff Join Date: Sep 2009
04-30-2010, 08:36 PM | #7 |
Official Lounge BAMF
My mom's car did that a few years ago (it was a 3.8 though). It had a crack in the intake manifold. It would run hot when sitting still or in reverse but not when going forward. Might want to check for that since you said you saw coolant leaking.
05-01-2010, 02:53 AM | #8 |
Loving the F body
Drives: 97 Firebird 3.8L 5 Speed Join Date: Nov 2008
doubtful it would be the intake manifold on the 3.4, it was just a very common problem on the 3.8
My OLD Car 1995 V6 3.4L Camaro -K and N Air Filter
http://www.camaro5.com/forums/showthread.php?t=10174 Current Cars -Modified 97 3.8L 5 speed Firebird -2003 Toyota Highlander Past Cars -1985 2.8L 5 speed S10 Blazer -1995 Chevy Camaro V6(130k miles) -1990 Mercedes 300E(280k miles) RIP 6-08 due to a Mustang GT that did not pay attention |
05-01-2010, 04:14 PM | #9 | ||
SS #2431
So what I'm getting out of all of this is that it could be one or several things. What would you recommend doing first? Bleed the system first and if that doesn't help take it in? |
05-01-2010, 04:39 PM | #10 |
05-01-2010, 06:39 PM | #11 | |
As for the leak, if it's on the oil pan then it's either a) leaking above it via a lose hose or bad connection or b) most likely being blown back there while driving. I still think the leak is a bad water pump and what little you've seen is what is being blown back from the weep hole. |
05-02-2010, 01:03 AM | #12 |
SS #2431
Alright, I'll probably do that sometime tomorrow. thank you guys for the help.
