07-05-2012, 10:15 PM | #1 |
The Machinist
Drives: 2012 2SS/RS LS3 IBM silver rally Join Date: May 2012
To Weld or not to Weld?
I just received my ARH headers and i noticed it came with a few clamps. Will it make any difference if i go ahead and weld those or should i use the clamps?
07-06-2012, 06:10 AM | #2 |
AKA "Beefcake"
Drives: 2023 ZL1 Sharkskin Join Date: Oct 2009
use clamps. Never know what you will have to be taking off and putting back on in the future. It will give you better options down the road.
07-06-2012, 06:13 AM | #3 |
Drives: 2011 2LS Camaro Join Date: Dec 2011
Clamp! You can't predict the future
07-06-2012, 06:16 AM | #4 |
Drives: 2012 2SS TF3, 1971 Chevelle Join Date: Feb 2012
And if the clamps are U Bolt style, throw them away and order the flat stainless steel seal clamps from Summit Racing that do not crimp our otherwise damage your pipe.
They come in lap joint style and in butt joint style, and for each diameter. An example http://www.summitracing.com/parts/sum-692300 Sent from my Galaxy Nexus using Tapatalk 2 |
07-06-2012, 07:18 AM | #5 |
Drives: Florida Speed & Power Join Date: Jan 2011
07-06-2012, 11:02 AM | #6 |
Drives: Fast Join Date: Oct 2011
+1 for using clamps for ease of removal, if you ever have to.
07-08-2012, 09:08 PM | #7 |
The Machinist
They are the clamps that came with the headers from ARH. Those good enough?
07-08-2012, 09:45 PM | #8 | |
Quit being a pu$$y
I welded up my entire exhaust, except for where the headers bolt to the mid pipes. This way there are no leaks, I am not carrying around 5 lbs of unnecessary clamps, I don't have to worry about my exhaust loosening up and sagging or rubbing on something under my car.
It still comes off very easily just like the stock exhaust. Quote:
07-09-2012, 07:22 AM | #9 |
Drives: 2011 ss camaro Join Date: Aug 2010
welded mine.
10/28/2010 got it
07-09-2012, 07:51 AM | #10 | |
220/221 whatever it takes
Drives: See sig.... Join Date: Jun 2010
Brent
2022 BMW X5 M50i 2022 Ram TRX 2021 GT500 CFHP 2016 Challenger Hellcat A8 1058whp/898wtq 1970 Chevelle SS396 4spd |
07-10-2012, 02:54 PM | #11 |
The Machinist
Ok thanks guys
