07-26-2018, 10:21 PM | #1 |
Drives: 2010 SS Join Date: Apr 2018
wtf is this?! 😮
On break at work today, i noticed this strange piece of thick fabric hanging from my drivers side wheel well. It was halway coming out, so i tugged at it a little bit until i got it out. I have no clue what this is, how it got there, if it was from the inside of my car.. And what purpose it served. If anybody has any idea, please let me know. Im curious.
07-26-2018, 10:27 PM | #2 |
Big Crow
Drives: '13 ZL1 Join Date: Mar 2017
That is sound and heat type insulation. I don't know where it is on the camaro. Something not covered in metal I would expect to be attached to the bottom of the hood or under the dash or carpet. If you aren't missing any under the hood I'd guess the car in front of you is now.
07-26-2018, 10:31 PM | #3 |
Cyber/orange10
inner fender by door hinge?
07-26-2018, 11:19 PM | #4 |
Drives: Camaro V6 Join Date: Oct 2016
It looks like either the front fender to door seal or the sound deadner for the wheel well housing. However, the front fender to door seal on mine is foam material, not pressed insulation backing like that one.
07-26-2018, 11:48 PM | #5 |
Camaro- Life Member
It should sit at the back of your front fender on the inside vertically. Meaning not where you can see it with the door open, but other side of the back of the fender. Hope that makes sense, 13 hour work day plus 3 hours paperwork and night time meds.
15 2SS/RS LS3 M6 Summit white
16 200 40mpg Vivid Blue Pearl 19 Tahoe 5.3 Boring Grey 91 Camaro RS 305 TBI 700R4 85 Corvette - TBD 05 Envoy 4.2 4x4 |
07-27-2018, 05:53 AM | #6 |
Drives: 2011 2SS/ RS INFERNO ORANGE L99 Join Date: Dec 2012
Thats from nowhere on the outside of the car.Did you run over something.
07-27-2018, 06:39 AM | #7 |
Drives: 2010 2SS-RS, IOM, M6 Join Date: Mar 2012
Its something you ran over there is no material like that on the bottom of the floor board on the outside...OR is your floor board rusted out where its coming from the inside ?
2SS/RS, Inferno Orange, 6sp, Eibach lowering springs, Eibach adjustable sway bar, Exhaust 2.5" dumps before axle, New ERA OTR intake, TSP LS3 225/230 .617/.612 on a 112LSA cam,
Rocker arm trunion kit, ported/polished heads, JRE Tune, ARH Headers, G-Force Axles, 3.91 Gears, Eaton Detroit Truetrac /w Billet Caps, MGW Shifter, DynoTech Driveshaft, E2X Catch Can . |
07-27-2018, 06:50 AM | #8 |
Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
Take your inner wheelwell spash shield off and put it back in there. It's insulation between the wheel opening and door.
07-27-2018, 07:06 AM | #9 |
Drives: 2011 1SS/RS IBM Camaro Join Date: Jan 2011
Spike III Build 2011 IBM 1SS/RS [COTW 6/25/12]
This guy has the right answer. When I put my 3-D carbon vents in. The back side of the front fenders near the doors in the wheel well is where that is from.
07-27-2018, 07:09 AM | #10 |
Fender vents
07-27-2018, 08:46 AM | #11 | |
It may be black foam like mine. The early cars probably had that hood insulation type material and then they changed to the foam sponge like stuff on the later models. |
07-27-2018, 08:57 AM | #12 |
Drives: 2012 M6 ZL1. 2019 Altima.07 FJR1300 Join Date: Nov 2011
Thought it was a rat at first quick glance
07-27-2018, 09:31 AM | #13 |
Drives: 2010 Camaro Join Date: May 2014
07-27-2018, 03:16 PM | #14 |
Kept The Faith
Drives: 2011 Camaro SS Convertible Join Date: Jan 2007
2011 Vert - 2SS/RS 6spd Triple Black
