Old 12-01-2019, 04:41 PM   #1
ABM Camaro
ABM Camaro's Avatar
Drives: 2013 ZL1 A6 Camaro
what part is this and what glue works
This is coming off on my car, and was glued on but its not holding.
What glue did you use to hold it on? Or whats the name of the part or part number to order a new one?
2013 ZL1 Camaro A6. ARH Headers, K&N intake, Tuned by Tampa Tuning
2014
V6 Camaro bolt ons and E85
ABM Camaro is offline   Reply With Quote
Old 12-01-2019, 08:58 PM   #2
sbubbaklein
sbubbaklein's Avatar
Drives: early 2011 Camaro convertible
that is part of the quarter window and comes on it. 22829813 Left, 22829814 Right they cost about $210 each
Early 2011 LT Convertible, ZL1 bumper, hood, side skirts, belly pan and wheels, Truecarbon ECF hood extractor, K&N CAI, Elite catch can, Big Worm Bow Tie emblems, Jacfab bracket, Vitesse TC, BMR strut brace, BMR tunnel brace, NPP exhaust
sbubbaklein is offline   Reply With Quote
Old 12-01-2019, 09:13 PM   #3
ABM Camaro
ABM Camaro's Avatar
I google those numbers and it comes up the glass window. I just need the rubber molding part number.
2014
Old 12-01-2019, 09:39 PM   #4
sbubbaklein
the rubber piece is attached to the window glass. It only comes as part of the glass already. attached to it.
Old 12-02-2019, 11:55 AM   #5
ABM Camaro
ABM Camaro's Avatar
well that's a fun sucker.
Anyone glue it and make it stick?
2014
Old 12-04-2019, 07:07 AM   #6
ABM Camaro
ABM Camaro's Avatar
Anyone glue this with rubber molding back to the window with success?
2014
Old 12-04-2019, 10:54 AM   #7
sbubbaklein
why not try clear silicone seal. It will bond, waterproof, withstands temp changes. Get name brand such as 3m, loctite, gorilla.
Old 12-04-2019, 12:55 PM   #8
ABM Camaro
ABM Camaro's Avatar
I picked up Gorilla gel glue, JB weld ( which looks like its on the window ) and a tube of Flex Glue. Im not sure which Ill use yet. I do have a clear tube of silicon around.
2014
Old 12-04-2019, 01:59 PM   #9
sbubbaklein
on the locktite web site you chose the material to be bonded and they recommend clear silicone seal for rubber to glass.
Old 12-04-2019, 05:27 PM   #10
ABM Camaro
ABM Camaro's Avatar
Ill give it a shot. I removed the rubber, scrapped out the old glue, and tomorrow Ill reapply silicon
2014
Old 12-08-2019, 04:24 PM   #11
ABM Camaro
ABM Camaro's Avatar
I used the Flex Glue and it seems to hold well for now. I did one window at a time so I could leave my clamps on it for 24 hours. If its doesnt hold, its not to hard to redo.
2014
Old 12-29-2019, 05:57 AM   #12
DaddySS
Kept The Faith
DaddySS's Avatar
Drives: 2011 Camaro SS Convertible
I would also look into why it's coming apart. The rubber shouldn't encounter anything that separates it from the glass and the pressure from the door window sealing against it should be slight. It seems either the door window or the quarter should be adjusted.
2011 Vert - 2SS/RS 6spd Triple Black
DaddySS is offline   Reply With Quote
Old 01-21-2021, 12:29 PM   #13
Sam9Fender
Drives: chevrolet camaro
I solved a similar problem with hot glue from a nearby store. The glue holds perfectly for six months, while the result suits me as I do not see any cracks or something like that. I used the best glue gun model of 2020 because it was the only thing I had on hand at the time, and I needed to fix the problem quickly. Also, this glue gun did a great job when I was trying to fix one of the broken windshield wipers. I can vouch for its reliability as this glue has survived more than a dozen rains and damp air. I can't name the specific name of the glue since I bought the most standard glue gun glue from a hardware store.
Sam9Fender is offline   Reply With Quote
Old 02-02-2021, 03:04 PM   #14
mikeman
Banned
Drives: 2015 Camaro
A urethane adhesive for windshields would probably work best for that application.
mikeman is offline   Reply With Quote
