Old 09-24-2013, 02:20 PM   #1
Andys562
Andys562's Avatar
Drives: Black 2011 2LT RS
Curb Rash; Wheel Cracked... Drivable? *Pics*
Got some curb rash guys. Cracked the wheel VERY SLIGHTLY.
Should I be worried? Is it driveable?
I mean it is a forged wheel so I'm sure it's pretty strong.
I ordered a wheel from Forgestar (the maker of my wheels) and they said it'll take 6-8 weeks. I have no other option but to drive the car.
I don't really have the money to buy another set of wheels, even if they're temporary...
Any solutions?
By the way, IF ANYONE HAS A 20 x 9 FORGESTAR F14 WHEEL EITHER AS A SPARE OR JUST LAYING AROUND, LET ME KNOW. I AM INTERESTED! ANY FINISH IS OK, I CAN GET IT POWDERCOATED FROM A BUDDY.
THANKS!
Black 2011 2LT RS.
Matte Black ForgeStar F14, Fronts 20x8.5 - Rears 20x10.5
20% All-Around Tint.
Black Painted Heritage Grill, Emblem-less.
Black Rear Bowtie.
AAC P13 DRL's.
AAC License Plate LED's.
AAC Dome Light/Trunk Light.
AAC Tinted Sidemarkers.
AAC SMD Afterburners.
MRT V1 Exhaust.
PFADT 1.25" Lowering Springs.
Andys562 is offline   Reply With Quote
Old 09-24-2013, 02:45 PM   #2
fussboss
fussboss's Avatar
Drives: 2014 2LT RS
Thats not a rash... more like a full blown infection. I would not drive on that.
fussboss is offline   Reply With Quote
Old 09-24-2013, 02:53 PM   #3
jkchambless
Austin LT
jkchambless's Avatar
Drives: 1LT - Airaid,JBA Axleback,VMax PTB
Agreed....best not to drive on that.
jkchambless is offline   Reply With Quote
Old 09-24-2013, 02:56 PM   #4
Andys562
Andys562's Avatar
What can I do? I need to survive on 6-8 weeks.
I am not doing any highway/freeway driving by the way. Just on city streets.
Black 2011 2LT RS.
Black Rear Bowtie.
AAC P13 DRL's.
MRT V1 Exhaust.
Old 09-24-2013, 03:02 PM   #5
upflying
upflying's Avatar
Drives: '86 Monte Carlo SS
Better check you alignment too.
How about putting the stock wheels back on?
upflying is offline   Reply With Quote
Old 09-24-2013, 03:50 PM   #6
dkp2LT
dkp2LT's Avatar
Drives: '11 2SS, '11 C6 GS, '04 MDX
Assume it's holding air?? You have a spare in the trunk? If so make sure it's good & full of air also just in case.
dkp2LT is offline   Reply With Quote
Old 09-24-2013, 03:59 PM   #7
rock1962
rock1962's Avatar
Drives: 2018 Camaro SS
Like said before make sure to check pressure regularly and make sure crack is not getting worse. You know how many people are driving with cracked aluminum wheels, they can crack with low profile tires by just driving over railroad tracks with low air pressure. The wheel is not going to blow apart worse case it will start to lose air.
rock1962 is offline   Reply With Quote
Old 09-24-2013, 04:05 PM   #8
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
If you ask me, it looks like the paint is cracked, not the wheel.
The metal seems to have bent and stretched a little, causing the paint to crack. If the tire is holding pressure and you dont get really nasty vibrations when moving, I think you are fine for a little while.
I wouldnt go over 60 with it, or drive in the rain. BE careful, blowout on the front means youll have a hard time steering. But any competent driver can deal with a front tire running out of air under 60 mph on a dry day.
You can use soapy water around the area to see if you have a leak, bubbles will form if there is air leaking anywhere.
Old 09-24-2013, 04:39 PM   #9
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
If the wheel is cracked as opposed to the coating cracked, stop driving on it. Think of it this way. Now you need a new wheel or a wheel repair and that is going to cost you more than you want to spend. If the wheel fails you have no idea what the repair will be in addition to the wheel.
Old 09-24-2013, 04:42 PM   #10
ModBargains.com
ModBargains.com's Avatar
Drives: Widebody 2013 Mustang GT
Location: 1721 E. Lambert Rd. Unit C, La Habra, Ca 90631
I'd take the wheel to a wheel repair specialist to see what he recommends. I can't give you my best judgment just by looking at a picture, but if this was my personal car, just out of safety for YOU and the people driving around you, I would put the stock wheels back on if you still have them.
ModBargains.com is offline   Reply With Quote
Old 09-24-2013, 06:05 PM   #11
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
I wouldnt drive above 20mph on that and thats only to get it to the shop. one good bump and it might blow. Hit someone and your screwed.
JCunningham is offline   Reply With Quote
Old 09-24-2013, 06:22 PM   #12
MBS
MBS's Avatar
Drives: 2010 rs 2lt
Just spit on that thing and let her rip , Dont worry about a thing it should be just fine .Or maybe not? If that is just a brush a crub rim shot remind me never to buy those overpriced rims
MBS is offline   Reply With Quote
Old 09-24-2013, 06:30 PM   #13
Andys562
Andys562's Avatar
The problem is, I don't have any spare wheels. I might just order a tire tonight and get a tire put on and hold off on the rim for 6-8 weeks.
I've been driving for two days on it (yesterday and today) and no leakage...
I've been monitoring the tire pressure and seeing if the crack is getting worse and everything is ok so far.
I'm more worried about the RIM than the tire guys... I don't want the rim to break on me or something but something is telling me that's unlikely...
Black 2011 2LT RS.
Black Rear Bowtie.
AAC P13 DRL's.
MRT V1 Exhaust.
Old 09-24-2013, 07:01 PM   #14
ECCamaro
High Desert Camaro Man
ECCamaro's Avatar
Drives: White Convertible-Tan Top 2SS V8
I would get it repaired. I had a rim that was much more damaged on my Chrysler LHS and got it repaired. In my case the damage was so bad it caused a flat. I was able to get my rim repaired for $30.00. Try these guys maybe they can help.
http://forums.bimmerforums.com/forum...LISTS-in-SoCal!
ECCamaro is offline   Reply With Quote
