Old 04-17-2011, 10:32 AM   #1
BloodUSMC
Blood Sucking War Machine
Drives: Black 2011 Camaro 2LT/RS - A6
Squeek and weird sounds!
We had a storm last night rain and wind. Woke up this morning beautiful weather. Car looks great. Cleaned it up and started driving. Heard some sound like stuff falling from the car I pulled over and everything seems good. I started driving again and it sounded like a metal hitting another metal. Most likely the rotors cuz I hear it only when driving.
When I pulled up to park the car. I put the car in reverse and drive again and a sound pops up like a metal piece popping.
Called onstar to try to get me connected with gm but they are closed on sundays same as service center.
What do you guys think?
BLACK 2011 2LT/RS COUPE. Roto Fab Intake, MRT 1.0, OBX LT Headers, Magnaflow resonated x pipe, Trifecta Tune
BloodUSMC is offline   Reply With Quote
Old 04-17-2011, 10:41 AM   #2
NoSyT
It's a Three Six, Vee Six
NoSyT's Avatar
Drives: '12 AGM 2LT/RS & '14 Silverado LTZ
Have you gotten underneath and looked? Is the sound coming from the front or rear?
NoSyT is offline   Reply With Quote
Old 04-17-2011, 10:54 AM   #3
BloodUSMC
Looked underneath from the sides. ( didn't lift the car up.) Didn't see anything. This sound is coming from the front end.
Old 04-17-2011, 10:54 AM   #4
Epitaph
Custom User Title
Drives: Fast
My wife's car did that a few years back, it ended up being one of the struts. Do you happen to live on a bumpy as hell road?
Epitaph is offline   Reply With Quote
Old 04-17-2011, 10:57 AM   #5
BloodUSMC
Not really but I did pass by some bumpy roads. But the struts will make the sounds all the time? I don't think that's it it doesn't sound like it.
Old 04-17-2011, 10:57 AM   #6
BloodUSMC
It sounds more like 2 metals griding against each other. When the car is moving only
Old 04-17-2011, 10:58 AM   #7
BloodUSMC
The faster the speed the less I hear it.
Old 04-17-2011, 11:28 AM   #8
BloodUSMC
Bump
Old 04-17-2011, 12:42 PM   #9
NoSyT
NoSyT's Avatar
Me personally, I would put it on stands and take the front wheels off and check everything...put your hands on everything under the front half of the car, compare left side to right side, etc...
Old 04-17-2011, 12:55 PM   #10
oldfriend
Drives: Fiat 500 E
The way you say it i think it is from the wheels hitting something , the reason is when you stop there was no noise [i am assuming that the engine was running ] , as speed up the sound goes [appears ] to go away , so you should lift the car on the front and by hand make the wheel move and see what is hitting what , one wheel at the time .
Old 04-17-2011, 12:58 PM   #11
BloodUSMC
Thanks I will do that when I get home tomorrow. It upsets me cuz I just shed out 30k and I'm having problems after only a week!
Old 04-17-2011, 04:37 PM   #12
LimaCharlie
LimaCharlie's Avatar
Drives: 2011 Camaro SS/RS - 2004 Silverado
There could be a piece of metal in the front end that blew under your car during the storm. Lift your car up and check everything......or take it to the dealer. Is it a popping noise, grinding noise, etc?
2011 Summit White Camaro 1SS/RS
-6.2 LS3, TR6060, 3.45, G80
2004 Black Silverado 1500 2WD Regular Cab, Short Bed
-5.3 LM7, 4L60E, 3.42, G80
2014 White Caprice PPV
-6.0 L77, 6L80E, 2.92, G80
LimaCharlie is offline   Reply With Quote
Old 04-17-2011, 04:52 PM   #13
BloodUSMC
Grinding noise. But when I put it in reverse and drive again it sounds like a ball in a can popping
Old 04-18-2011, 02:22 PM   #14
Chevrolet Customer Svc
Drives: GM Vehicles
BloodUSMC, have you ever had your vehicle checked for the issue you are describing? Thank you.
Jeff Morris, Chevrolet Customer Service
