Old 04-14-2016, 01:30 PM   #1
HOU_TX_SS
Drives: Camaro SS
416 F1X Power Loss After 6k RPM
So Im looking for any assistance or input with an issue we are seeing on the dyno. I am in the process of getting a speed density tune with Pat G in Victoria, Tx and we are seeing an issue. The power and torque pretty much go straight up with a very smooth line to about 6k RPM and you start to see power loss and jump in the data. You can also hear it from the car that its slightly cutting out and we let out of it. This happened a few pulls and it was just too hot so we shut it down. Pat says its not knocking and the VE tables are all perfect. Fuel is not an issue either (Fore Innovations double pump return style system). We think it may have to do with spark plug (BR7EF) gap or something of that nature. When its cutting out slightly around 6k you can also see light flames coming from the exhaust. Just looking at input to see if anyone has experienced this. Thanks.
Justin
Fully Built 416ci / Procharger F1X / Century Built 4L80 / ZL1 Differential / Alky Control Meth /Circle D Triple Disk / ID1300s / Fore Innovations Return / Kooks Full Exhaust / Holley HiRam / e85 / 15in Conversion on Forgestar Beadlocks / Tuner: Pat G
HOU_TX_SS is offline   Reply With Quote
Old 04-14-2016, 02:55 PM   #2
trw427ss
trw427ss's Avatar
Drives: 2013 2SS/RS L99
What are the plugs gaped at?
2013 2SS/RS L99/A6 Crystal Red Metallic Tincoat 12.76@108.98mph Bone Stock
12.46@111.19mph with New Era CAI & U/D Pulley
12.12 @ 114.16 after Stainless Power headers and no tune yet on stock P-Zero's!
12.007@ 115.20 With 18" Drag Radials - 11.93 @115.19 Added a PTB 11.76 @116.59 With Yank SS3200 Converter - 11.63 @116.52 After PI and Tuning 11.44 @118.75 New Best
10.72 @127.93 after heads and Cam and Yank SS3600
trw427ss is offline   Reply With Quote
Old 04-14-2016, 03:05 PM   #3
HOU_TX_SS
Drives: Camaro SS
I need to double check them all but I want to say .026. What do you recommend?
Old 04-15-2016, 02:28 PM   #4
trw427ss
trw427ss's Avatar
.026 should be fine. How much boost are you making?
Old 04-15-2016, 02:34 PM   #5
Unreal
Drives: 2006 Z06
Valve train?
Nick
Corvette Z06 -1200ish rwhp
Old 04-19-2016, 10:39 AM   #6
HOU_TX_SS
Drives: Camaro SS
UPDATE
Pulled plugs and gapped to .026" and as a result, power pulls clean to 7000 with absolutely zero knock retard. Here is a video of a pull with the "Spark Blow Out."
https://youtu.be/svRpVDGzZUQ
Old 04-19-2016, 11:24 AM   #7
DarrinSmartL99
Drives: 2010 Camaro SS/2SS
I saw you car there saturday, very nice. Kurt and Patrick are great guys. My dad has known Patrick since 1998.
DarrinSmartL99 is offline   Reply With Quote
Old 04-19-2016, 11:37 AM   #8
Nitroman28
Nitroman28's Avatar
Drives: 2010 Camaro SS 416/4L80
What was the gap at before?
Nitroman28 is offline   Reply With Quote
Old 04-19-2016, 11:48 AM   #9
HOU_TX_SS
Drives: Camaro SS
Thanks man I appreciate it. I've been through several local tuners and Pat and Kurt are in their own category. We you there for a tune?
Old 04-19-2016, 11:49 AM   #10
HOU_TX_SS
Drives: Camaro SS
Im honestly not too sure. I thought they were .026", but I'm guessing not. When you start making big power your shit has to be spot on.
Old 04-19-2016, 12:45 PM   #11
mrebusa
mrebusa's Avatar
Drives: 14' 2SS 1LE
What'd the car end up making?
14' 2SS/RS/1LE - NPP - K&N - TSP 1 7/8
Soon:
mrebusa is offline   Reply With Quote
Old 04-19-2016, 01:06 PM   #12
camarosspower
camarosspower's Avatar
Drives: 2010 camaro ss
How come it just spit fire off from the passenger side and not both?
camarosspower is offline   Reply With Quote
Old 04-19-2016, 03:14 PM   #13
HOU_TX_SS
Drives: Camaro SS
Made 912hp/721tq.
Old 04-19-2016, 03:15 PM   #14
HOU_TX_SS
Drives: Camaro SS
Thats a good question. I have a full Kooks exhaust which has a x style pipe in the exhaust. Im not sure why it did that Maybe something to do with the issue of spark blow out.
