05-25-2016, 04:46 PM | #1 |
Drives: LSX FTW Join Date: Feb 2016
E85 HELP
Alright guys need some help, Converting over to E85.
Now, Are Ls9/LsA/zL1 injectors sufficient or is there a better alternative for the cost? Already ordered a zl1 fuel assembly as well as the fpcm. might be going with the dsx flex fuel sensor as well. anything else im missing? car will be getting tuned for both 93/e85. thanks in advance for any input. |
05-25-2016, 05:40 PM | #2 |
Svt lol
Drives: 2011 ss inferno orange blown Join Date: Jan 2012
Depends on your power level. Basic math is whatever you need for you hp goals double that for e85.
05-25-2016, 05:46 PM | #3 |
Too much is never enough!
Your going to use a ZL1 fuel pump with an ADM FPCM and some injectors from a ZL1, to run E85?
What kind of power do you plan on making?
05-25-2016, 05:50 PM | #4 |
Drives: 2013 Camaro SS Turbo Join Date: Apr 2014
If you are NA the zl1 injectors will work. Have a few cammed ls3 friends running e85 with them no problems. Who is tuning the car?
05-25-2016, 05:56 PM | #5 |
not going to be fi for a while, my Silverado makes great power off of e85. I know it wont net me anything over 20rwhp tuned with a stock cam. possibly the guys over at lashway or redline in south florida.
05-25-2016, 06:02 PM | #6 | |
https://facebook.com/dsmlightstuned/
05-25-2016, 06:14 PM | #7 |
I've heard about dsmlights, I know he's done a couple of my vett buddies. im not expecting anything crazy with it but its worth it in my opinion. not sure if the setup I want to run is sufficient however, maybe someone whos done it could chime in for a na with bolt ons
05-25-2016, 06:19 PM | #8 | |
05-25-2016, 06:21 PM | #9 |
will do, thanks for the help man!
05-25-2016, 07:11 PM | #10 |
Tuning is nothing really. You turn on flex fuel, and copy in some tables from a flex fuel car. The rest is the same tune as your E0, so if a tuner can do one, he can do flex fuel.
Nick
Corvette Z06 -1200ish rwhp |
05-25-2016, 08:58 PM | #11 |
THE U
Drives: Camaro 1SS/RS Join Date: Jul 2015
My tuner recommended fics or id injectors because he doesn't like running LSA/9 injectors on LS3 manifolds. The spray angle is wrong.
05-26-2016, 01:23 AM | #12 |
Moonshiner
Drives: Holden SS-V L77 flex fuel Join Date: May 2012
You need the flex (ZL1) pump, not the injectors. E38 FPCM stays unchanged for NA, handled by ECU. Use the GM fuel composition sensor, no need to complicate a toothpick.
I'd use a flex tune OS to start rather than flagging bits and copying bobs higgledy piggledy. Ethanol flex can be really fuel efficient, use GM tables and modifiers base tune for 2013 L99 or 2014 VF Commodore.
Compression is King.
Naturally as-pirated, all-motor, all alcohol. |
05-26-2016, 07:17 AM | #13 |
camaro tune is flex fuel OS.
Nick
05-26-2016, 07:18 AM | #14 |
Moonshiner
E85 HELP
Ah, not it isn't. Different calibrations required for flex fuel vehicle, massively different. Instead of creating a Frankentune you are much better using a flex base tune.
Naturally as-pirated, all-motor, all alcohol. Last edited by pir4te; 05-26-2016 at 07:46 AM. |
