06-16-2016, 06:27 PM | #1 |
Drives: 2014 SS Convertible Join Date: Jun 2015
Advice on cam swap.
I currently have the vector motorsports 2.5 cam and are looking for more power next year. Do you guys think it would be beneficial to swap out to something like the night fury? I hear about how well the torque on the NF cam is, but i don't know enough about cam specs. Any input is appreciated.
Vector Stage 2.5 = 227/239 .613/.623 114+4 Night Fury Cam = 233/242 .629/.629 113+3 |
06-16-2016, 08:40 PM | #2 |
Drives: 2010 Camaro 2SS/RS Join Date: Apr 2016
All depends on where you want the power at. What supporting mods do you have with the Vector Stage 2.5?
06-16-2016, 09:00 PM | #3 |
Drives: 2014 1LE, 1996 z28 Join Date: May 2015
I wouldn't think you would pick up more than like 15 peak HP, with a probably loss in power under say 3.5 or 4K.
Not worth the cash IMO. |
06-16-2016, 09:32 PM | #4 |
That's where I was going with it I would either boost it or throw a 150 shot.
06-17-2016, 02:34 AM | #5 |
Don't think its worth the swap.
06-17-2016, 02:40 AM | #6 |
Drives: 13' 1LE Join Date: Apr 2012
Dont do it. Get some ported GM heads instead. A true gain would be going for a solid roller LL from cam motion.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
06-17-2016, 07:12 AM | #7 |
old school chevy rodder
Yup not worth the change little difference and the LSA is still about the same with advance added also.
06-17-2016, 07:31 AM | #8 |
Thanks for the replies guys. I finally updated my mod list in my signature. I'm thinking of doing the TSP ported heads as they are only $750 and reputable.
Other ideas i'm throwing around are a 25% UDP and maybe some water / meth injection to get some more timing and make the car run the same when its 60 or 90 degrees out.
Engine: LSA Conversion, Ported Heads, 1 7/8 headers, VMS 2.5 Cam, Roto Fab intake, ADM Scoop. BMR engine mounts, 3.91
628/525 Suspension: Koni orange, (BMR everything) 1" drop springs, toe rods, trailer arms, non adjustable LCR, FE4 sway bars, sub frame connectors, delrin sub frame bushing and upper control arm bushings. Front bushings. |
06-18-2016, 06:34 PM | #9 |
Drives: ‘13 1LE Join Date: Jul 2013
Not much of an option that you left on the table if you ask me.
Answer would be negative. Are there any swap options out there that would be worth doing? Absolutely. +1 on the LL, for his application. |
06-18-2016, 07:05 PM | #10 |
What cam would be a better option for street?
06-18-2016, 07:16 PM | #11 |
"For The Street" "for The Track" "for Occasional Track"....it's a hard line to read into....1/4 mile....1/8 mile....but after reading your first intro post, "for the street" doesn't seem to be the limiting factor here .
Generally speaking, Hydraulic cam (like yours) is more livable for "street" and typical street end users. LL cam is when the limiting factor, "street" quote on quote, doesn't apply anymore, and you want every available thing on the table to toss at it. If you are going to do heads anyways, I would LL that sucker, and get my extra xx HP that I left behind . For NA that is. |
06-19-2016, 04:26 AM | #12 |
I did some research on the LL cam, still kinda confused about all of the finer details. What I'm gathering is its.....a lot of cost and possibly need new springs each year. Or am I missing something?
06-19-2016, 08:05 AM | #13 |
Solid rollers just need their Lash/preload measured are reverified /adjusted.... the problem with them is they do beat on the valve train more in some ways, not as in changing springs every year....
06-19-2016, 08:50 AM | #14 |
Drives: 2010 Camaro 2SS Victory Red 6M Join Date: Apr 2015
Yeah a LLSR cam isn't really much harder on the valvetrain than any other aggressive hydraulic roller cam. The main thing is the added cost of better lifters and rocker arms. Periodically, you have to pull the valve covers and check the cold lash to make sure they're still in spec. Other than that, springs should last pretty much the same. They'll need to be replaced about 20-30k miles depending on how much you lean on the loud pedal.
2011 2SS 6A Red Jewel Metallic, Vararam Tune CAI, Magnaflow 3" Competition c/b, Speed Engineering 1-7/8 LT's, Circle D 5C, M/T 275/40R20 S/S, HPTuners tune by Ryan@GPI
12.3 @ 112 ACM as of 12/22/19 Gone on 12/28/19 R I P 2010 2SS 6M Victory Red/Black (old ride) CAI intake, Speed Engineering 1 7/8" LT's, X4 base tune, Flowmaster Outlaw axle-back. 12.6 @ 115 SAR as of 9/19/15 Gone but never forgotten. |
