07-27-2016, 08:37 PM | #1 |
Drives: 1968 firebird Join Date: Jul 2016
Another cylinder head question
Hello all. What are you guys views of the Trick flow 255 gen x's and the AFR 230CC heads. Or the mast 245cc heads. The trick flows are a little more. On my build all I have is the rotating assembly built. I have no cam, was going to
Base that on my head choice. Engine is 416 ls3. Just looking for strong power and a good power range. What would you guys do? |
07-27-2016, 10:37 PM | #2 |
Are they all rectangle port?
07-28-2016, 01:27 AM | #3 |
Drives: 2010 Camaro 2SS Victory Red 6M Join Date: Apr 2015
If you can spend the coin, the AFR CP heads combined with the matching FAST intake will make some absurd power. However, that being said, the TFS heads are no slouch either.
2011 2SS 6A Red Jewel Metallic, Vararam Tune CAI, Magnaflow 3" Competition c/b, Speed Engineering 1-7/8 LT's, Circle D 5C, M/T 275/40R20 S/S, HPTuners tune by Ryan@GPI
12.3 @ 112 ACM as of 12/22/19 Gone on 12/28/19 R I P 2010 2SS 6M Victory Red/Black (old ride) CAI intake, Speed Engineering 1 7/8" LT's, X4 base tune, Flowmaster Outlaw axle-back. 12.6 @ 115 SAR as of 9/19/15 Gone but never forgotten. |
07-28-2016, 07:45 AM | #4 |
The only CP heads I see are coming up for a BBC
07-28-2016, 07:50 AM | #5 |
old school chevy rodder
Trick flows will change out the geometry some thus making it a question as to compression ratio, and getting the right pushrods selected I know that, I do not know about the others AFR no I think for changing geometry. Money is always a big deal, Me I went GMPP CNC heads for the price about $1300 a pair complete and down the road if I win the lotto: Mast small bore ls7 heads which flow tons that well..... I would not really need with a milder cam like the stage three cam motion I am running now and stock intake. Basically why spend a fortune if your not spending one on all the other components...? I think for our cars the TSP 235/239 is one of the best if not the best out there for off the shelf performance, sure theres others with yada yada and a huge duration but that's not so good and then there is changing out springs anyway down the road. You really need to decide where your going with the build and how far for what reason. I could not justify in my mind a few extra hp for 1200-1500-2000 more...... I could see getting some one like Bo to clean up a CNC gmpp head for some coin.
07-28-2016, 08:02 AM | #6 |
i was actually going to go with the TSP 235/239 cam. But i didn't know how it would sound or perform in a 416. IIRC correctly, someone told me that that was small cam for that size engine. You guys know way more then me. My intentions are to spray the engine with a 300 shot with a controller. And would like to have 550rwhp but that seems a little bit out the way.
07-28-2016, 02:04 PM | #7 |
LSx CP heads = cathedral port. My bad for not clarifying.
07-28-2016, 02:43 PM | #8 | |
Taco's 2014 SS
Mods: 417 Stroker | CAI | Bo's PTB | Kooks LTs | Flowmaster Outlaw Catback | Night Fury Cam | Powerbond UDP | Apex Catch Can |PRC Ported Heads |FAST 102 Intake |Suspension Crap| Built by J-Rod. |
07-28-2016, 02:44 PM | #9 | |
Drives: 2013 2SS/RS L99 Join Date: Oct 2012
2013 2SS/RS L99/A6 Crystal Red Metallic Tincoat 12.76@108.98mph Bone Stock
12.46@111.19mph with New Era CAI & U/D Pulley 12.12 @ 114.16 after Stainless Power headers and no tune yet on stock P-Zero's! 12.007@ 115.20 With 18" Drag Radials - 11.93 @115.19 Added a PTB 11.76 @116.59 With Yank SS3200 Converter - 11.63 @116.52 After PI and Tuning 11.44 @118.75 New Best 10.72 @127.93 after heads and Cam and Yank SS3600 |
07-28-2016, 03:06 PM | #10 |
What cam would you recommend? sorry I meant to say 200 shot.
07-28-2016, 05:53 PM | #11 |
I only recommend a nitrous cam when your going to spray it all the time.
08-01-2016, 09:25 AM | #12 |
Drives: Camaro Join Date: Apr 2009
I think it would be very hard to find a head to beat the PRC 260 heads & the value you get with them. Better than stock p/v for extra milling. 68cc chambers to begin with for a compression boost, hollow stem valves standard (not $200 upgrade) Pac .660" springs standard, free milling to your camshaft specs.... The list goes on & on!!
http://www.texas-speed.com/p-4010-pr...der-heads.aspx |
