Old 06-13-2018, 11:01 AM   #1
rgrmoreira13
rgrmoreira13's Avatar
Drives: 2015 2SS 1LE
416ci
Hey I am considering in getting my engine and getting a 416ci stroker but to handle boost.
1. Who has this application on a M6 transmission ?
2. How much power are you making with this setup or FI ?
(My overall idea is to get the 416 and get it boosted with a D1x and maybe add 12lbs of boost.)
Specs and info on what you have done would be greatly appreciated.
Specs
TSP Stage 2 Boosted Cam 227/235 at 114 LSA
Fore Innovation Triple pump staged (Walbro 342 primary and 2x Walbro 450 secondaries)
Procharger D1x with a 3.85 pulley
ID1050x Injectors
Flex Fuel Sensor
Monster LT1 Twin Disk Clutch
Holley Sniper Efi Intake Manifold
NW 103mm Boosted TB
747rwhp at 12psi on E85
rgrmoreira13 is offline   Reply With Quote
Old 06-13-2018, 11:30 AM   #2
LsxDoctor
15 Year LS1Tech Member
LsxDoctor's Avatar
Drives: 2010 ss 391ci LS3
It can range anywhere from 500rwhp to well over 1k rwhp. Just depends on what your goals are and how much money you want to spend.
Heres an 830rwhp 416 ls3 with an F1a (#15 boost)
https://ls1tech.com/forums/forced-in...s-fun-2-o.html
LsxDoctor is offline   Reply With Quote
Old 06-13-2018, 11:42 AM   #3
rgrmoreira13
The 416 will be meant for a boosted application but I wanna test drive it.
The goal was to begin at 650rwhp with the procharger. But I think I can do even more. I am curious to see what a boosted 416 stroker does naturally aspirated. Yea I know it sounds a bit confusing.
Specs
ID1050x Injectors
Flex Fuel Sensor
NW 103mm Boosted TB
Old 06-13-2018, 12:04 PM   #4
perfucto
perfucto's Avatar
Drives: 2013 ZL1
416 LSA with a 2.9 Whipple
I am running a 416 LSA with a 2.9 Whipple. Some stuff is different from the photo. Running a Gates HD Green belt, 2.875 upper pulley etc.
perfucto is offline   Reply With Quote
Old 06-13-2018, 12:45 PM   #5
rgrmoreira13
oh man this is going to look beautiful. I am anxious to see what I can do with my setup.
For now I am going to add the procharger D1x soon after.
Specs
ID1050x Injectors
Flex Fuel Sensor
NW 103mm Boosted TB
Old 06-13-2018, 02:02 PM   #6
trw427ss
trw427ss's Avatar
Drives: 2013 2SS/RS L99
The D1X in not all it's cracked up to be it only makes boost at high RPM's way down on boost in the mid-range! A D1SC or a F1A would be a better choice!
2013 2SS/RS L99/A6 Crystal Red Metallic Tincoat 12.76@108.98mph Bone Stock
12.46@111.19mph with New Era CAI & U/D Pulley
12.12 @ 114.16 after Stainless Power headers and no tune yet on stock P-Zero's!
12.007@ 115.20 With 18" Drag Radials - 11.93 @115.19 Added a PTB 11.76 @116.59 With Yank SS3200 Converter - 11.63 @116.52 After PI and Tuning 11.44 @118.75 New Best
10.72 @127.93 after heads and Cam and Yank SS3600
trw427ss is offline   Reply With Quote
Old 06-13-2018, 02:10 PM   #7
perfucto
perfucto's Avatar
Drives: 2013 ZL1
I'm at 925 rwhp 862 rwtq at 17lbs. of boost. Plenty of torque throughout the range. Maybe check out a Whipple.
Old 06-14-2018, 08:29 AM   #8
rgrmoreira13
Wow did you do anything else to that 416 ???
Specs
ID1050x Injectors
Flex Fuel Sensor
NW 103mm Boosted TB
Old 06-14-2018, 11:32 AM   #9
perfucto
perfucto's Avatar
Drives: 2013 ZL1
All Manley forged internals, Mast heads, Redline Phase 4 cam, 93 with 100 meth (dual nozzle). Check our Redlines site we did the Redline Phase 4-ZL with the Redline forged 416 short block. Call Howard Tanner for more info, 954-703-5560.
Old 06-14-2018, 12:10 PM   #10
rgrmoreira13
That's who is going to do my block.
Specs
ID1050x Injectors
Flex Fuel Sensor
NW 103mm Boosted TB
Old 06-14-2018, 12:53 PM   #11
perfucto
perfucto's Avatar
Drives: 2013 ZL1
Howard, Roy, Brandon and Rich are a great Team. You can't go wrong.
Old 06-15-2018, 07:11 AM   #12
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
A 416 N/A is dependent on the cam but should crank out numbers similar to a ls3 only with torque numbers about 50 ft lbs more and being larger can use other options such as some more radical things that a stock block would not so much benefit from such as a stroker CAM, small bore ls7 heads, a ls7 manifold to go with them and a 102. Just some thoughts, and the mast windage tray had to be clearanced even more. I bought my short block new block form Custom engine supply via the net, also known as SAG performance and they sell on ebay guy called Jerry the machinist, in Angola Indiana good informative, and their work holding my 428 together well, I used Molnar rotating and Racetec pistons.
Old 06-15-2018, 03:17 PM   #13
rgrmoreira13
I am hoping that I get a bit more than the stock LS3 in aspect of power.
The bottom end will be forged and I am looking to see what type of heads I should get in regards for better airflow.
Specs
ID1050x Injectors
Flex Fuel Sensor
NW 103mm Boosted TB
Old 06-15-2018, 05:01 PM   #14
eLeSthree
Drives: 2011 Camaro SS 6sp
Thumbs up
I say stick the D1 on the stock motor and have some fun, while saving up for the forged short block. Then you can always upgrade the head unit later.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
