Old 08-17-2017, 03:35 PM   #1
13ashengrey
13ashengrey's Avatar
Drives: 2013 2SS Ashen Grey
ANYONE MAX OUT A D1 ON STOCK BOTTOM END?
Just curious if anyone on here has maxed out a D1 on their stock bottom end. Ive done bigger heads and head studs and just want to see if the bottom end can handle it. Im gonna find out either way just wanted to check.
5.98 @ 115mph
13ashengrey is offline   Reply With Quote
Old 08-17-2017, 04:16 PM   #2
BiggFoot
BiggFoot's Avatar
Drives: 2010 Camaro (M6) 1000+ HP SBE
How much psi/HP is a D1 capable of putting up?
When I discussed the issue with my shop there was more concern about HP than psi on the bottom end. I suppose more HP generates more heat and that is the concern?
I don't have a D1, but anyway you shake it I am running 900+ HP on a stock bottom end. Other than some "spirited" driving once or twice on the street I haven't really tested this setup, but that is about to change. I will be taking it to the track on Sat 8/26 to see what it will do when I hammer down on this thing. Guess I will see if it holds together after making several runs.
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam
Brodix BP BR 3 Heads
Kooks LT Headers and full 3" exhaust
Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion
DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears
McLeod RXT Twin HD Clutch & Upgraded Slave
RPM Level VII
TR6060
BMR Drag Suspension Package w/Strange shocks
Carlyle 15" and M/T ET Street R radials
10.1 @ 143 mph 1/4 mile
BiggFoot is offline   Reply With Quote
Old 08-17-2017, 08:24 PM   #3
QUICRNU
Drives: Z06 wannabe
Apex Focused
QUICRNU is offline   Reply With Quote
Old 08-18-2017, 08:20 AM   #4
Trob85
Svt lol
Trob85's Avatar
Drives: 2011 ss inferno orange blown
the psi and tune will determine how it holds together. I'm running a 3.4 pulley on my p1 making 11# at 6700 I could still spin the blower another 7-8000 rpm before it's maxed. This winter I'm going to take it back for the d1x upgrade. As long as the tune is on should be ok and I should mention I wouldn't hurt to run either meth or in my case e85.
Trob85 is offline   Reply With Quote
Old 08-18-2017, 10:59 AM   #5
13ashengrey
Procharger told me the 3.4 pulley will put me 12-13 psi. I should be 850+
5.98 @ 115mph
Old 08-18-2017, 11:00 AM   #6
13ashengrey
I've considered running meth as well
5.98 @ 115mph
Old 08-18-2017, 11:44 AM   #7
mrimpala02
Drives: Black 2SS RS w/White Stripes
I say do it! If the fuel and tuning is right it will be find. Like anything else, if you beat on it everyday something may break or maybe nothing will happen. That's just the risk you take when hot rodding though.
2010 2SS/RS "ChriSStine":
Pat G Custom Turbo CamMotion Camshaft | AGP TT BB Garrett 62/65's | AGP/Fore Triple Pumps | ID1700X Injectors | Alky Control Twin Nozzle Meth | Custom 3" Exhaust | 3.27 gear set w/ Tru Trac | McLeod Twin RXT | Barton Short Throw Shifter | 6th Gen ZL1 Wheels | BMR 1.4" drop springs | Pfadt rear trailing arms & tie rods |
Installed by Me & Tuned by Pat G
mrimpala02 is offline   Reply With Quote
Old 08-18-2017, 12:23 PM   #8
13ashengrey
The pulley and belt should be here any day. Then I have to schedule a day with Mike Norris for tuning. I rarely drive on the street it's mostly track. So it will get beat on. I'll post dyno results and track times. At 660hp I went 7.0 1/8 and 10.81 1/4.
5.98 @ 115mph
Old 08-18-2017, 12:39 PM   #9
Taylortoons
Taylortoons's Avatar
Drives: 2011 2SS/RS LS3
What cam are you using at 660/592?
GPI Built Procharger D-1/13 PSI/Race Intercooler/SS3 Cam Kit/Kooks LTH/X- pipe/FIC 1050/E85/3.91 gears/Centerforce Dual Disc clutch/Flowmaster Outlaw/775whp/680tqSOLD
Taylortoons is offline   Reply With Quote
Old 08-18-2017, 01:24 PM   #10
fif_gen_powa
fif_gen_powa's Avatar
Drives: 2013 Camaro SS Turbo
Those numbers seen very optimistic, what fuel you running?
388ci 91/104 Turbo TH400
8.3@164
https://instagram.com/turbo_ls3/
fif_gen_powa is offline   Reply With Quote
Old 08-18-2017, 01:59 PM   #11
BiggFoot
BiggFoot's Avatar
I am thinking that at 13 psi you should be about 800 hp but hey, if you can squeeze 850 out of it then that is great!!
To go from 660 hp to 800-850 hp will really make a difference. You should be in the 10.2 -10.4 range if I had to guess!!
A pulley and belt is cheap HP!! Hope your drive train and fuel system will take the extra 150 hp!
Blower Cam
RPM Level VII
TR6060
Old 08-18-2017, 02:08 PM   #12
13ashengrey
I have the Texas speed blower cam. I'm on 93 octane with the LPE Dual pumps and 80lb injectiors.
5.98 @ 115mph
Old 08-18-2017, 02:11 PM   #13
mrimpala02
Pumps are good for the power on 93, but you may need meth to safely get 800 rwhp.
Old 08-18-2017, 02:42 PM   #14
Trob85
Svt lol
Trob85's Avatar
I'm curious to see what you make also.
